Results 1 to 14 of 14
Thread: Ecotec engine mounts?
    vh
    Dec 2009
    Default Ecotec engine mounts?
    Where are they? I inspected a vx v6 not long ago and was wondering where they were? And how many?
    And how do you know if they are worn down? I know in my 1st car (nissan) i could see one of the 4 easily and you could tell how worn it was?
    Obviously you will notice a difference driving quality with worn mounts, But I would like to know how to visually inspect them if possible???
    Nov 2003
    Quote Originally Posted by smi5575 View Post
    Look under your right header down at the chassis and for the left its near the air con compressor. I assume a tell tail sign they are rooted is the sump touches the cross member like mine does.
    I don't think them looking over cracked is a good thing either.
    vt/vx ls1
    Jul 2009
    the engine mounts are below the eqaust manifolds.there is two 'one on each side'. the rubber may have to much movement or perishing or cracked.. i think oil is no good for them either if you have oil leaks in your motor... you may be able to see the damage or feel the movement.. im not sure if you can see them through the engine bay or not its been a while since i had a v6-but im sure if you had a small mirror you would be able to..or you may have to look from under the car.. this is just wat popped into my mind when i read ur question.. im far from a mechenic..
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    there is a metal rod that goes through the bottom side of the mount.
    if you can get under the car and see how far the rod is to the bottom of the mount then you will no how shagged they are...should be 10mm or more...
    vh
    Dec 2009
    No worries thanks for the advice. I wish they were easier to see lol.. When im looking next time I will do the "engine mount test" basically you put you foot on the break and the car in gear and push the car forward slightly, you want the engine to stay firm and no big movements, if it jumps around then, they will need replacing..
    But thanks guys
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Just get under the car and have a look??? They're easily noticable. If your sump is touching the crossmember, then they're definately in need of replacement. But also if they have large cracks in them they could do with replacing too.
    LthlThrt's Avatar
    LthlThrt is offline Chef Jay in Port Douglas
    02 VU II SS
    Mar 2009
    Port Douglas
    how much do they usually cost for a new set of engine mounts? i will need to replace mine before i get back on the road
    Nov 2003
    Quote Originally Posted by LthlThrt View Post
    AllCarbits in Coopers Plains has them for $90 a pair.
    LthlThrt's Avatar
    02 VU II SS
    Mar 2009
    Port Douglas
    Quote Originally Posted by Locksmiff View Post
    thanks for that ill give them a call on monday cheers
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    yes definetly replace them before they touch the sump! or else you'll have what i have! a 5cm long 3mm deep wear mark in the sump:S the slightest knock to it and the sh%t will hit the fan!
    vh
    Dec 2009
    Quote Originally Posted by drift-it View Post
    You mean hit the road and the shit will be your oil lol
    showbags's Avatar
    showbags is online now Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    dont be tempted to buy the cheap non-hydrolic mounts. they're crap. the hydrolic mounts absorb a lot of vibration and make them much nicer to drive. hydrolic ones are about $85 each but worth it
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    vh
    Dec 2009
    Quote Originally Posted by 97bermudacalais View Post
    Thanks ill be sure to look into that if i need to buy any
  1. v6 vt engine mounts
    By D-Man in forum GSL RallySport
    Last Post: 15-06-2010, 12:40 PM
  2. Vs engine mounts. Can we get a how to?
    By fonzo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2010, 08:43 PM
  3. Engine mounts??????????
    By INNAWE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2009, 06:24 AM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine mounts
    By RockyC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2005, 12:21 PM
