Results 1 to 4 of 4
Thread: Secvice at 170,000
    VX Executive V6
    Jan 2010
    Question Secvice at 170,000
    Hey guys
    Just wondering in terms of a service what is bst for the car, mods are coming soon so not to concerned about cost's, just wondering what products should i use eg. top gun, ngk, drift oil filter, k&n filter, what oils etc etc.
    cheers
    VL V8 & supercharged VX
    Nov 2006
    western vic
    ngk 4 spark plugs K&N air filter and oil filter and some nulon oil thats all good stuff and its not to dear.
    Dec 2009
    Quote Originally Posted by jbangr View Post
    Hey guys
    cheers
    Just service it according to your service booklet and use genuine parts I have found them to be good quality and usually much cheaper.
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    and power flush and treat the rad and heating system...
    and power flush the brake system...
    upgrade the sway bars with new links
    check all wheel bearing
    do your springs and shockies
    as in whatever needs it...at least all shockies first up...
    get the air con checked and new rec dryer if its never been done...
    replace the water pump... and check all tension and idle pulleys
    check all rubber s and mounts on exhaust
    flush and clean out the wiper motor and tank..
    drop the auto tranny filer and oil and put in new...
    drop the man transsion oil if you have that instead..
    and do your diff..
    all the bushes and that you opt to go to syn instead of rubber..
    that will keep you busy...)
