Results 1 to 9 of 9
Thread: A few VT problems
    VT Executive Series 1
    Jul 2008
    Default A few VT problems
    Hi, I have a few problems with my 97 VT.
    - Get a squeeking noise when wheels are turning, doesnt happen all the time.
    - at low speed I hear rattling coming from under the car, cadalic converter maybe?
    - Blinker switch, occasionally makes noises like I have the blinker on even though I dont.
    - The brake makes a noise whenever I take my foot of it. I Did recently change the brake pads.
    any info on what the cause is and how to fix them would be greatly appreciated.
    thanks
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    ok....
    well....lets see...
    squeaking noise..could be since you used new brake pads ....you never got the discs machined...
    and possible is ..there is a ledge in the running surface...
    option 1 get them machined.....
    option 2 could be that the anti shatter of pads is lost its full flex...and they need replacing...
    option 3 it could be you need to take the pads out...and where the pads are running the back of pads ...not the braking part...or surface...apply some copper grease....
    the blinker ...replace the blinker relay and fuse with new ones...
    and inside blinker unit with a new unit ....
    the rattle noise could be anything under a car....could exhaust...like loose rubbers --anti vib ..or clamps..etc
    could sway bars or links worn or loose
    or springs or shockies...
    have that checked...a rattle is usually metal on metal.....and that is not good
    Jul 2008
    ok, thanks for the reply.
    will give them all a go.
    The rattling is like a tinny sound and it only does at certain revs, usually round the 30-40 km mark...
    theres also a clunk on the drivers door when we go over a bump, like the door isn't closed properly but it is.
    And another thing, sometimes when I stop, I only usually notice it when I pull up in my driveway, when I put the brake on it makes a creacking sound, like somethings stretching?
    thanks for the help
    Feb 2010
    near bundy in qld
    the rattling is more and more like exhaust ...deal...and could be rubbers in the brackets
    check the clunking in the door...its most likely related to the audio speaker....however it could be window winder related...so check that out....
    a craking sound could be...in the brakes.....could be abs related or could be calliper...
    you need to have a look at it
    VTrock is offline Doesn't fit = hammer
    Vt Executive
    Apr 2010
    Hey mate had the clunking in my passenger side door a few weeks back had to loosen off bracket on b pillar, lift bracket all the way up and tilt back and re-tighten haven't heard a noise since
    hope that helps
    Beau
    Jul 2008
    thank you for the info guys, looks like I have a bit of work ahead of me, lol
    MikeCuzzy's Avatar
    MikeCuzzy is online now How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Blinker stalk is a common problem with age, recently had mine replaced. You could do it yourself for about 40 bucks. Just swap out the assembly.
    Jul 2008
    Quote Originally Posted by MikeCuzzy View Post
    Oh ok, thanks for the info
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by Mel0307 View Post
    Even if you get a mechanic to do it, 100 bucks. Just depends on how much experience you have- or how game you are.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  3. Vz sv6 problems help!!!!!!!
    By allanssv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-03-2009, 08:27 PM
  4. a/c problems
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-10-2008, 10:48 PM
  5. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
