Results 1 to 12 of 12
Thread: oil in the water
    VT S2 wagon Berlina
    Dec 2008
    Default oil in the water
    Hello all
    my radiator seems to have oil in it.
    the oil dipstick isnt foamy or anything like water into oil.
    what does oil into water ?
    VL V8 & supercharged VX
    Nov 2006
    western vic
    i wouldnt be worried about it if u get like creamy milk on ur dipstick then thats a problem.
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    your car is an auto transmission...
    the oil is leaking from the transmiisson cooling section of the rad ...
    into the water cooling section of the rad...
    best way to fix this...is....
    bypass the cooling in the rad...and get a small cooler from the wreckers for auto trans
    and prefered is a size about at least....as long as the standard rad is long but say 9 inch high
    however you can get away with shorter one...maybe 2ft long and 6inch high...
    route all the current auto trans oil from entry and exit points on the current rad...
    to the new rad...and block of all old rad holes...
    the car will now use the total amount of the rad...and your tranny the new rad...
    OR buy a new rad
    Or have the rad repaired
    VT S2 wagon Berlina
    Dec 2008
    thanks
    I only noticed it as the expansion bottle was low.
    It does look at bit browny, red.
    Any idea on the price of a fix or replacement radiator ?
    vt ss commodore series 2
    Sep 2009
    Geelong, Aus
    Chances are....if oil from the tranny has got into the radiator water then water from the radiator has got into the tranny. I'd look into that too before it does any damage to the tranny.
    Feb 2010
    near bundy in qld
    a new rad is about 200 bucks or less
    that brown red coloured water is a sign of boiling of impurities out of water in the rad and engine and heater...
    that means your not using a coolant mix...and weaking the ratio with water too much...
    and its in need of a good flush...
    so when you place the new rad in or yours repaired...and its better off being new!
    cause we talking about an item that if it defects it kills your engine...
    Clean your system.....and flush it out..
    heater pipes lines...overflow bottle...
    and if you need to replace a $200 rad.including its new rad top..replace the $80 water pump...and $25 themostate
    and use 1/2 coolant to water mix and fill the system...and in a few weeks
    drop it out and flush it
    and refil with new stuff...
    then top ups are coolant only....
    and replace where needed faulty pipes or clamps...
    then you protected the lot !
    and system flushes are every 1 year
    VT S2 wagon Berlina
    Dec 2008
    thanks
    I can get a radiator for $150.
    Will try and do it with a few mates. I cant find a how to on this site. Anyone have one or know of one on a different site.
    A radiator place said to put a but of degreaser in the radiator. run few a few kilometers. this is to help when flushing the system.
    sounds a bit weird.
    any help full hints to make this job easier ?
    a how to would be really good.
    VT series 2. Auto. only the oil cooler on the passengers side.
    I hear I need to do something with a bleed screw.
    VX Executive
    Feb 2008
    What if the coolant reservoir tank is cracked? I just noticed it when was taken a look at the coolant in the reservoir but when i filled it up it spilled all over the floor, shined a light down the neck of the container and saw a crack! First the CATs, then yesterday was the windshield and now the cracked coolant reservoir. The car drives really well though and no signs of overheating. The coolant is in the normal level and i'm using premixed Castrol coolant
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I would replace the overflow bottle as soon as possible to avoid overheating issues. When the coolant gets very hot some goes into the overflow bottle and then gets sucked back into the radiator when it cools down.
    MY RIDE
    vt olympic edition 99 model
    Apr 2010
    i once had cracked heads on my vt and in the morning the car would start idle roughly for a minute or so then be fine its was spitting water out the exhaust manifold as far as i know but i never had the milky look to my radiator i did have overheating problems with the way the car was until i got another engine now i have a set of heads that i used for a week on the engine then the bottom end spun a bearing. so i took the heads off now there just sitting there doing nothing .
    VT S2 wagon Berlina
    Dec 2008
    Quote Originally Posted by darren44 View Post
    thanks
    sounds a bit weird.
    back to my question.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    say rad again
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
  1. VX leaking water but water tep guage shows normal ???
    By FIN990 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2009, 12:51 PM
  2. water in oil
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2009, 08:10 AM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. car covers . water proof vented vs water resitant non vented
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2005, 01:20 PM
  5. Water in Car
    By blue alliance in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2004, 05:41 PM
