Results 1 to 5 of 5
Thread: Engine Light
    vt
    Mar 2010
    Default Engine Light
    Hello all,
    My engine light comes on,stay's on a bit then goes out then when driving will come on again,i've heard about connecting pins 5 and 6 under the steering wheel,will this work on a 1998 vt,and also,when i pinch my radiator hose steem will come from the top of the radiator,can i put good tape on this area for now,thanks..............
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    From where in the "top of the radiator"? But that doesn't really matter, putting tape on any coolant system leaks aint going to hold in 140 odd psi.
    HBD VT Calais SII L67
    Mar 2010
    newcastle
    my guess is uve got a split ??? is your temp guage making its way up to hot, that would possibly put your engine light on, and putting tape on a radiator isnt really going to work it mat only be about 15 psi in there but the water and heat will wreck the tape real quick
    if its not to big of a crack and its in the plastic, as a band aid fix go to repco and pic up some stuff called Q-Bond sets like cement and is made to be used on radiators
    vx s pack II
    Jan 2010
    aLKIDA
    Bridge pins 5&6 works on the V6 VTs not V8s
    Read the error codes and look up on the forum what the code means go from there.
    vt
    Mar 2010
    thanks,the radiator leak is on another car,the vt engine light comes on,will brige the pins.
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. Engine Light and Trac Light
    By Quantum in forum General
    Last Post: 02-06-2006, 11:33 PM
