Results 1 to 19 of 19
Thread: VT error code 57
    VZ
    Oct 2008
    Default VT error code 57
    hi guys..i have a VT V6 commodore and lately its getting hard to start..i have to crank it for heaps before it starts..i have done a error code check and it comes up with 57..does anyone know what that relates too and how do i fix it??
    any help will be much appreciated
    vx s pack II
    Jan 2010
    aLKIDA
    Code 57 - Injector power supply voltage variation
    Check EFI relay (Swap it over for another one then start the car.)
    Check PCM connection and supply to the injector with multimeter. (PCM supplies Negative to the injectors)
    PCM could be faulty.
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    If that is the Ecotec, the same as the VS, then fault code 57 should be: Injector Power Supply Monitor (voltage variation, terminal B12).
    That's according to my Gregory's VS book anyway..
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Code 57: Injector power supply monitor (voltage variation, terminal B12)
    That's all I can tell you.
    Edit: A bit late I see.
    MY RIDE
    vx s pack II
    Jan 2010
    aLKIDA
    The B12 terminal on the PCM.
    Power comes from the EFI relay to the PCM B12 connection.
    PCM triggers the injectors.
    Add from previous post you can also check for signal at the B12 terminal positive supply (Use multi-meter)
    VZ
    Oct 2008
    Quote Originally Posted by PRAVX II S View Post
    thanxs for the reply prav..but for a noob like me im finding it hard to understand..where is the PCM and EFI relay located..also i do have a multimeter..how can i tell if the efi relay is stuffed??
    would appreciate your any feedback you give..
    cheers!!
    vx s pack II
    Jan 2010
    aLKIDA
    PCM is located on the passenger side kick panel.
    The EFI relay I think is located under the bonnet. Open the bonnet and were your window washer is near the battery there should
    be a plastic cover under there should be the relays/fuses. (On the bottom of cover there should be a diagram of whats what.)
    The EFI relay is a 4 pin relay (It has 4 legs underneath/connections)
    Swap the EFI relay over with a identical one try the air-con relay check if it is the same. And try to start it.
    For the PCM check I would suggest get a mate or auot-elec to do it if your not confident because you can stuff the PCM up if you short pins.
    And there is more things involve in testing.
    VZ
    Oct 2008
    prav, your advice has been great so far..i have access to a multi meter..can you please tell me what i need to do to check the PCM and what i should be looking for?
    is there anyway of checking the EFI relay with a multi meter also?? i dont know anyone with a commodore to swap the relay with..
    i do have LPG installed, but the problem happens on either gas or petrol, either cold or warm..
    vx s pack II
    Jan 2010
    aLKIDA
    If your car is fitted with air-con then I think the relay will be identical. So just swap the air-con relay with the EFI one in your car make sure there the same though. I think the air-con relay is under the bonnet with the other relays?
    For the PCM you will need to find the injector trigger wires on the PCM I don’t know the colors of my head. But they supply a negative to the injectors.
    So you will need to see how many volts are coming out of the wires (There will be a couple of injector wires)
    VZ
    Oct 2008
    prav..the a/c relay is the same as the fuel pump relay (both in engine bay)..where would the EFI one be??
    vx s pack II
    Jan 2010
    aLKIDA
    Don’t use the Fuel pump relay because you need it to run the car. Use the Air-con one.
    If there is no EFI relay under the bonnet were the fuel pump one is (Check under the fuse cover for what relay is what). Check inside the car (drivers side)There is a panel that sits under the steering wheel pull this panel out and you will see another fuse box
    VZ
    Oct 2008
    mate ive looked high n low for this efi relay..cant find it..ive looked in the engine bay, ive looked under the steering, like youve suggested..still cant find the bloddy thing..its a VT calais if that helps..any idea where it could be?
    vx s pack II
    Jan 2010
    aLKIDA
    Its should be under the bonnet mate. Is there a relay that says IGN? try this
    turn the reds on.
    Take the relays out one by one (dont mix the relays up one by one)
    If you have taken out the right relay then there will be no power on the B12 on the PCM. Thats your efi relay. (when reds are on there will be power on this terminal so by taking the relay off you will kill the power to it and thats your EFI relay.(use multi meter)
    So taking relay out and making sure there is no power at the b12 terminal on the PCM.
    vn ss
    Feb 2010
  15. #15
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by mickymodge4 View Post
    is the car on dual fuel???? if its on dual fuel this code is normal
    Could be true, I have not had much EXP with lpg just petrol as a auto-elec
  16. #16
    VZ
    Oct 2008
    why is that?? i dont think i ever remember this code coming up before..its not a factory LPG conversion if that matters..
    PRAV, are you saying that the EFI relay is the one that says IGN?? i would have thought that this would be something to do with the ignition?
    if this code 57 is normal, i wonder what else is causing this to happen..its becoming a pain in the ass..sometimes it takes ages to start..just keep on crankin and crankin..sometimes it fires straight away..anyway its doing my head in..
  17. #17
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by muneey View Post
    Try the IGN relay and see if it takes power off b12 on the pcm and swap the IGN relay over for the same one.
  18. #18
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
  19. #19
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by codeunknown View Post
    no it will be the contoller marked relay does the EFI
    Yeh i know that but this dude cant find it under the bonnet so i thought to give that i try.
  1. error code 47
    By mynameisearl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2011, 05:05 PM
  2. ABS Error code 28
    By Dan366757 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2009, 10:55 PM
  3. Error code 46 on VR
    By Equipe VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2007, 09:10 AM
  4. Error Code 27 ??
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2006, 09:55 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
