Results 1 to 12 of 12
Thread: Intermittant acceleration issues Gen3
    VS Series II Exec
    Nov 2004
    Default Intermittant acceleration issues Gen3
    Good evening to you all,
    I'm having an acceleration issue with a VT SS Gen 3. It has recently clocked up 100,000kms and went into Holden for a major service (the 160,000kms one, air, oil, fuel filters, platinum plugs etc). I explained that I was experiencing average acceleration when planting the foot and they said that after a test drive they could not fault it!
    Now i'm turning to the help of the good folk at Justcommodores for assistance! Ok, so this is what happens:
    1) Slight rough idle and on a couple of occasions the revs have dropped to around 500rpm-750rpm before picking up again.
    2) Once warm, cruising at say 70kms/hr and planting your foot, it used to remain in the same gear and accelerate like a V8 should, although now it always wants to kick down a gear and even then, the power is just not the same (huge flat spot).
    3) When climbing a hill, the car feels like it has less guts than my old VS 6 cylinder.
    4) Fuel usage has been steadily increasing.
    Holden's solution for something they couldn't find (HAHA shock horror!!! They always find the problems that aren't there and miss the obvious ones), was for the fuel system to be cleaned out with one of their $155 fuel cleans but before I decide to go ahead with that I thought I'd get some advice on here. I was thinking that as it is highly unlikely the spark plug leads have been changed since new, could it be possible that an arching/dead lead could be the culprit because it does feel like it's running on not all 8 cylinders?
    Feedback would be heaps appreciated.
    Cheers guys,
    Boojakz.
    vx berlina wagon 5.7
    Feb 2010
    Bendigo, VIC
    before you pay to have the fuel system cleaned out get a bottle of injector cleaner and run that through to see if that helps
    vt ss commodore series 2
    Sep 2009
    Geelong, Aus
    I had very similar problems with my gen iii. It could be a combination of things. The leads (according to my mechanic) should be replaced at 100k. Also check things like fuel filter caused by dirty fuel. Simply putting in a fuel additive won't always fix the problem asap. Also try running the car with the best possible fuel, ie premium
    with 98 octane. I would not recommend at this stage going for holdens additive as often as the case their product is just a glorified fuel additive you can buy at supercheap etc.
    VT SS S2 A4
    Aug 2005
    o2 sensors or fuel pump, or combination of both.
    I would start with the o2 sensors first.
    VXII Berlina 5.7L / VW Golf GTi
    Mar 2009
    South-west Sydney NSW
    I was having similar issues with mine. Turned out I had 2 clogged injectors. Got them cleaned out and it is noticably different!
    There are 2 types of pedestrians, the quick and the dead
    Check out my ride here....
    http://forums.justcommodores.com.au/...rlina-ls1.html
    VS Series II Exec
    Nov 2004
    I've running nothing but premium in the car since I've had it. The problem first showed it's head after I topped up with Shell vpower. I've run nothing but bp ultimate ever since hoping the problem would go away but it's been to no avail thus far. I'll top up tonight and put in a bottle of the nulon total fuel system cleaner and see how we go. Keep the feedback coming guys :-).
    Cheers,
    Boojakz.
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    I reckon you should give a set of new leads a go. I was driving a car which felt like it had less power, slightly rough idle, other than that, not much wrong, If you didn't know that type of engine before you'd think it was normal. But I chucked in a new set of Topgun's and the difference was amazing, felt like a new engine, I was very surprised with the results.
    carless for now
    Feb 2007
    perth,Western Australia
    you can try to go to a mech with a tech2 or holden they should point out any 02 faults but try some injector cleaner first
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    There are so many things it could be, leads, sparks, fuel filter, O2 sensors, air filter, blocked cats, injectors, MAF, temp sensor, and probably a bunch I haven't covered.
    I would start with the cheap easy ones, which don't hurt to do anyway like clean the MAF and throttle body (could be the cause of your rough idle), change air filter + fuel filter if they haven't been done for a while (though major service should cover both of these), run some injector cleaner, replace the leads if they are suspect or very old, same for sparks, O2 sensors will be on their way out around 160,000 if they are still original and would be worth doing.
    Good luck
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    VS Series II Exec
    Nov 2004
    Just topped up the tank with ultimate again and put in a dose of injector cleaner so we'll see how it runs in the next few tanks. The car has just clicked over 100,000kms but i just had the major of all major services that Holden offer and that's the 160,000kms one so they replaced the air and fuel filters and replaced all plugs, so they're off the checklist. I'm leaning towards a dead lead at this stage but we'll see how the injector cleaner goes first. Keep the feedback coming guys :-).
    Cheers,
    Boojakz.
    VS SS
    Mar 2009
    hmmmmm funny this exact same problem has just come up on my car tonight....wh gen3
    Vt SS S2 5.7
    Jan 2010
    When i first purchased my car i thought it was ok not having anything to reference it against. After its service they changed the plugs, leads and fuel filter and O2 sensors at my request and to be honest the difference was dramatically noticable. It could have been a combination or one of these, with a tune that made such a difference, but i would start there in conjunction with your injector additive..... good luck with it mate, make sure you post the culprit when ya find it, incase i get it again in the future :O)
  1. Intermittant Indicators
    By Bob123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2009, 12:21 AM
  2. Intermittant problem... need help please
    By buggzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2008, 07:21 PM
  3. VN Intermittant Stalling
    By madvoice in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2006, 08:06 PM
  4. Gen3 Losing power on acceleration
    By ants308 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-02-2006, 11:58 PM
  5. Possible Problem : Acceleration issues.
    By NXNVR-6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2005, 10:11 PM
