Results 1 to 3 of 3
Thread: URGENT - Lost speedo signal
    HSV GTS VTII
    Mar 2010
    Default URGENT - Lost speedo signal
    The car has a speedo converter on it from KPH to MPH incas that is relevant. The Speed is sat at 0. If i do the Mode up trick the digital output is 0. The dash test shows the needle moves fine.
    What is first to check to prove if its a signal issue or the converter???
    Thanks
    vt/vx ls1
    Jul 2009
    is there a signal to the converter??? have you checked the speed sensor...???
    why do you have a converter anyways?? is it for the drag track?
    HSV GTS VTII
    Mar 2010
    This is now reolved. It was powered of the cigarette lighter and this has shorted out.
    The converter is to allow the dash to read in MPH with out new dials. Also then all the trip computer will read in MPH too.
  1. Speedo signal wire for speedo corrector
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2009, 08:14 AM
  2. Speedo playing up, urgent help needed
    By Troy5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 06:09 PM
  3. URGENT help required. lost car keys
    By s0sage in forum The Pub
    Last Post: 23-10-2006, 12:31 PM
  4. speed signal
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 02:49 PM
  5. Crank angle reference signal (no signal) code 47
    By gc-tec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2004, 10:29 PM
