What's with my VX? I have replaced my brake light globes and have reset my computer ( disconnecting the battery) but still getting the brake light warning light on the dash. It seems to come on a couple of seconds after i put my foot on the brake and turns off when the foot is released...
Can someone help me find a solution?
replace the globe in the stop light in your back window.
Are you sure its the bulb warning light, If it is then do as above, If its not and is the fluid level light check your brake fluid level, Either is low or the sensor is stuck down.... If its low i would be checking your pad front and back to see if they are worn out.. Low level is a god indication that the pads are low (If the system has no leaks)
check that your replacement globe is of the same wattage or replace both globes with the same brand to balance out the check relay
check brake fluid
dont use brakes
