Results 1 to 9 of 9
Thread: Traction Control question
    VX berlina ecotec/ vy ss ute
    Sep 2009
    Default Traction Control question
    hi i was wondering i have a v6 vx berlina series 1, when traction kicks in it cuts out my car but i thought there were ment to kick the accelerator pedal back towards you?
    thanks
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Nope, VX traction control works by starving the engine off fuel and is not throttle based. The VX has a physical cable that connects the pedal to the TB and no mechanism to push the pedal back up.
    So you floor it, loose traction, traction cuts fuel, you faceplant into the steering wheel but your foot can stay pressed to the floor with no feedback.
    VZ's onwards had 'fly-by=wire' throttle and had the pedal puch back when traction control kicked in.
    In this setup, there is no physical cable from the pedal to the TB and everything runs on electronics. So there is a servo @ the pedal that can be influenced to give feedback through the pedal.
    Cheers.
    Sep 2009
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by Jesterarts View Post
    So you floor it, loose traction, traction cuts fuel, you faceplant into the steering wheel but your foot can stay pressed to the floor with no feedback..
    can the vx traction control be switched of? or be rewired to a permitly off switch?
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Press the button.
    Or for a more permanent solution, take the fuse out
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    hence why no traction control with a holden on LGP mode of fuel...
    only traction control on unleaded
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    You can probably get your ECU reprogram so it defaults trac control to OFF on startup, but I don't see a need for it.
    I'd rather forget to turn trac OFF and faceplant into the steering wheel than forget to turn it ON and end up sideways in a shrub.
    MikeCuzzy's Avatar
    MikeCuzzy is online now How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    No traction, plus water = AAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH H *Spinning car* AAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHH
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    the VX V8 kicks pedal, cycles engine, and applies rear brake's. in that order, if sustained loss of traction.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
  1. stability control...traction control???
    By m05tw4nt3d in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-03-2011, 09:30 PM
  2. Question Re Traction Control 5.7 V8
    By holden#1 in forum General
    Last Post: 06-12-2009, 08:28 AM
  3. Vy Traction Control
    By ucrvme in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-06-2009, 02:22 PM
  4. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  5. Traction Control
    By eagleaus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2006, 10:57 AM
