Results 1 to 8 of 8
Thread: fuel gauge
    LthlThrt's Avatar
    LthlThrt is offline Chef Jay in Port Douglas
    02 VU II SS
    Mar 2009
    Port Douglas
    Default fuel gauge
    hey there guys my fuel gauge is not working the best it reads half a tank but is full, when i turn the car off the needle drops nearly all the way down (past the empty) and i just filled it up and it only comes up w/ half a tank, is there like an adjuster behind the dash that i can tweek to make it work?
    99 VT Commodore
    Mar 2010
    south east queensland
    mine doesnt seem to read correctly either, ive got a vt v6 and it drops randomly slowly decreasing then will go back up counting the "km's to empty" up higher to where it was before it dropped....
    replace fuel sender? or what could it be?
    VX acclaim series II wagon 2002
    Mar 2010
    Queensland
    My empty on my fuel gage is quarter of a tank. so when i fill my car i only get 3 quarters instead of a full tank. i need to get a new electronic fuel pump and fix the fuel float. you may have to do the same thing.
    Mar 2010
    Queensland
    or it may be your fuel gauge is faulty, its a common problem. with mine its the fuel float but yours seems like the gauge. try and replace the fuel pump first if that doesn't work, try the relays and if that still dont work then its the fuel gauge. hope this helps
    LthlThrt's Avatar
    02 VU II SS
    Mar 2009
    Port Douglas
    Quote Originally Posted by CV6Z View Post
    mine is like when you wind the clock back half an hour and it is always half an hour behind if that makes sense, ill try get a photo up, but you could have a bad level system? th part inside the tank that tells you how much you have left, sounds like that could be the problem.
    LthlThrt's Avatar
    02 VU II SS
    Mar 2009
    Port Douglas
    Quote Originally Posted by holdenman84 View Post
    the relays in the engine bay? stupid question but where is the fuel pump located in the car? and would it be a simple matter of replacing theneedle? or a bit more complicated
    99 VT Commodore
    Mar 2010
    Quote Originally Posted by LthlThrt View Post
    yeah thats what i mean you nailed it, maybe the "leveling system" is faulty? how would i go about checking this? or what would i be looking for? im good with mechanical things and have a full workshop where i live (on a farm in Mundubbera) gf's dad is a mechanic with his own business here =P
    mine seems to do what your sayin aswel - says its empty but really theres about quarter of a tank still there...its fustrating cos i go to fuel up and all of a sudden theres more fuel than i put in lol
    Mar 2010
    Queensland
    its a plastic fuel tank that you got, the fuel pump is on the top of the fuel tank bolted in which means you have to take the complete fuel tank off the car to replace the fuel pump. it is located under the boot. and yes the relay in the engine bay.
  1. temp gauge an fuel gauge not working
    By nathan_867 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2010, 10:55 PM
  2. Faulty Fuel Gauge/fuel pump unit VU SS ute
    By paul.stewart2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-02-2010, 09:48 PM
  3. Fuel / Fuel gauge problem
    By 2ndLook in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 06:50 PM
  4. Fuel gauge stuffed? or engine just drinking fuel?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2007, 05:51 PM
  5. Fuel Gauge - Low fuel Warning
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2005, 07:08 PM
