Results 1 to 3 of 3
Thread: plenum cover question
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Default plenum cover question
    hey, i want to take off the plenum cover so that i can clean all the junk out of the plenum and throttle body.
    my question is, do i need to replace any seals or gaskets between the plenum cover and the plenum? or is it just a matter of undoing the 8 bolts on top and pulling it off?
    seen a few threads on here about cleaning it, but none say whether there is a gasket, and if it needs to be resealed, or just put back on after.
    thanks in advance
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Literally you just undo the bolts and pull the top off, there are rubber seals on the bottom of the plenum, but no gaskets or anything.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    May 2009
    Gold Coast
    sweet as man, thanks. what about the IAC? do i just pull it out and clean or do i have to replace the O ring?
  1. ecotec plenum cover studs
    By vsdore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2010, 10:18 PM
  2. [QLD] [B]Selling Ecotec Intake, Plenum, Injectors And ThrottleBody + Engine cover [/B]
    By BIG-EV in forum Parts And Other Items For Sale
    Last Post: 20-08-2009, 09:59 PM
  3. Torque on Plenum cover hex bolts?
    By Slippy_Trippy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2009, 08:48 AM
  4. air plenum-valley cover.
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2008, 10:47 PM
  5. Plenum cover under windscreen wipers
    By VTS07 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-08-2007, 06:50 PM
