Results 1 to 3 of 3
Thread: fault code 92
    vt equipe wagon
    Feb 2010
    Default fault code 92
    just did the whole fault code thing and it came up with 92, which is low speed fan fault.
    what does this mean? is it serious? would it explain why the car is not running right?
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    low speed fan........works when the car is going so slow.....and its starting to overheat from that....
    i single fan kicks in to help provode air flow to keep the rad in check....
    if this dont work.....you have a second fan which will kick in to help out..when the car hits a certain heat range...
    now usually.....if untouched the problem is faulty relay.....
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by dubguy View Post
    Code 92 is a common problem and can usually be fixed with a new low speed fan relay but I doubt that it would affect how the car is running.
    MY RIDE
  1. Fault code 66
    By customfc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2008, 07:41 PM
  2. Fault Code 22
    By Tom_1569 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2008, 04:35 PM
  3. Fault code 13
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2007, 08:38 AM
  4. Fault Code 68?
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2007, 12:28 PM
  5. Fault Code Help
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 09:08 AM
