Results 1 to 7 of 7
Thread: vt auto
    vt
    Feb 2010
    Default vt auto
    hi i put a motor and auto box in a different car it was out of a vt when i started it the box was slipping could that be low oil? also i found it had bilt up presher in the dip stick (gearbox) the is i small host coming of it that i blocked so i unblocked it and now its fine (still slipping but) were dose the breather hose go? there is 3 hoses that all join but this is a smaller one i havent checked the oil yet but if its low would it slip thanks heaps
    VS SS
    Mar 2009
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    very undetailed....
    so did you put engine and gearbox from vt to vt ?
    can we assume it was an auto transmission ?
    sounds yoo unknown....
    vt
    Feb 2010
    ok i put motor and box into a ford transit van il bee doing the oil tomorow . if its low would it slip? and do you no were the small hose is ment to go (the hose from the box} thanks ps sorry boult the spelling
    Feb 2010
    near bundy in qld
    well is it a auto box.....?
    just checking....
    and it dont matter if its a manual or auto if it does not have the right amount of oil it wont run correctly...
    i guessing its a auto....and if its oil level is not 100% not only wont it work but you can damage the tranny...
    if you left it all connected...and never drained it...
    and shoved in a rage and sealed off the drive tial shaft...good...
    its been some time since i pulled out a auto tranny...i have to have a look at a spare vn auto i got in the shed...
    or check the workshop book...on the vt....
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by dady619 View Post
    I think the hose you a talking about is a breather hose and doesn't connect to anything.
    MY RIDE
    vt
    Feb 2010
    kool thanks and yes it is a vt auto box dont think i stuffed it just need oil id say i hope lol just when i first put it in drive it moved but reved up like it was slipping thanks again
  1. Auto VX V8 Gearbox Swap (with another auto)
    By Tom4321x in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-02-2010, 09:21 PM
  2. difference between standard auto and turbo auto
    By Nackerz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-11-2009, 08:56 PM
  3. Changine from Column Auto to Floor Auto
    By VNCPTR in forum General Discussion
    Last Post: 16-04-2009, 01:48 AM
  4. Fuel Mileage Holden VZ Wagon(auto) Vs Subaru 2.5(auto)
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 06:38 PM
