i need standard replacement piston rings... can anyone recomend a brand or type or part number please im not in the (know) when it comes to specifics!!!!
Last edited by matqld; 08-04-2010 at 01:02 AM. Reason: hoping someone wud help!!!!!
does 3.898 sound right for standard bore size???? and does 1.5 x 1.5 top and bottom ring and x 3 for the oil ring sound right????
does anyone know the original piston part number??? its dec 99 built ls1... thanking you guys!!!!
i realise i will need to file them ect... i just need some advice on wat (type-brand ect..). im having troubles finding a standard replacement ring kit.. oh n the part numbers wud be gud too plz...
i was ordering other parts from usa, so thought id get rings aswell just didnt know which type n wat not..... otherwise i wud probably be goin through holden...
Hey all, iv ordered my parts from the states from texas speed they are as follows,,,
Clevite H Main Bearing Set, For LS1 Stroker Applications 106.99$us
Clevite LS1 H Rod Bearings 79.92$us
Camshaft Bearing Set for 1st Gen LS1 Engine Block 41.99$us
Basic Bolt & Gasket Kit for LS1 Heads & Camshaft Swap-includes,
GM Multi-Layer Steel Cylinder Head Gaskets (p.n. 12498544),
GM Cylinder Head Bolts (p.n. 12498545), GM Water Pump
Gaskets, GM Timing Cover Gasket, GM Front Cover Seal, GM
Harmonic Balancer bolt. ( for the kit-159.99$us)
GM LS2 Timing Chain 41.99$us
GM LS6 Oil Pump 105.99$us
GM Oil Pump O-Ring for LS1/LS6 4.99$us
Sealed Power Complete Ring Set for Stock LS1 Pistons 119.99$us
Shipping 226.81$us
Total....$888.66 american dollars...
Wat do you think guys???? are they the right parts for my dec99 built ls1??? and wat do you guys think about the price? cost approx $990.00 australian dollars...
Mate why are you ordering them from the US i am sure that i would be easier to track some down on our shore.
GM LS1 GEN III SS NEW PISTON RINGS - eBay Engine Parts, Engines, Components, Car Parts, Accessories, Cars, Bikes, Boats. (end time 08-Mar-10 20:34:29 AEDST)
For all the Gaskets. Just go to Bursons.
very very expensive in aus!!!!! same part way dearer price!!! make sense..
the listing had finished on those ebay rings...
more feedback plz???????? thankuz....
