Results 1 to 5 of 5
Thread: Water collection in boot seals
    MikeCuzzy's Avatar
    MikeCuzzy is online now How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Default Water collection in boot seals
    Ok I'm sure you all have this problem, but the last week of rain has really pissed me off.
    Is there any way to stop the water collecting in the boot seals so when you open the boot the water doesn't drain onto my head/stuff in boot.
    Is there anything you can do about it?
    benjamino's Avatar
    benjamino is offline needing some more undies
    VX SS 6spd + 7psi
    May 2008
    The Sticks, WA
    hey mate if you have a spoiler its most likely the spoiler gaskets that are stuffed.
    It involves going to auto pro or whatever and buying a set, then taking off ur spoiler and sticking the new gaskets on.
    its that easy
    hope this helps
    450 good reasons to just power on
    yeaahhh
    VT S1 Commodore EXE 1999 with vx 3.8/auto
    Feb 2010
    near bundy in qld
    well apart from placing the car in a shed or under a carport...
    or covering it with a weather protector....
    the reason why you have water in the boot seal is more important...
    i have found that holdens attrack frogs ....
    and frogs love to live in the door jams and boots and bonnets closing points...
    what you need to do with your boot...is
    check the rubber is in tact..if not replace it or seal it...
    check that all the water area...around the rubber in the groove channel is clean ..in fact wax polish it clean...
    so the water sheds off...
    you could place a section of tart in the boot that sticks out under all points of boot corners ..
    you could use black plastic sheet as e well
    you will also find you get water getting in the boot lights...and running in the boot lid and boot floor that way..
    so the answer is really replace the boot lid lights seal and seal it good..
    VE S2 SV6
    Nov 2009
    Get a scriber or small screwdriver. On the inside of your boot lid near each corner you will find a half circle looking lump about (from memory) 8mm in diameter and 10mm long. Push your scriber thru the paint at the half round end. Behind the paint it will be full of putty. Scrape out all the putty and then the water will be able to drain out.
    Bit of a production line fault with the VT, they painted over the drain holes.
    I don't know how to post pics, but you look for long enough and you'll find em
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    @benjamino don't have a spoiler.
    @ Billy Bob sounds like that's the issue, I'll have a look after work tomorrow.
  1. Water in Boot
    By Rodeo058 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2009, 09:11 PM
  2. water in boot
    By dale s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2006, 01:21 AM
  3. Water pump seals
    By Gravy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2005, 07:03 AM
  4. Water in Boot Lid
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-06-2005, 12:29 AM
  5. VS - Water in boot lid.
    By pod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2004, 09:48 AM
