Results 1 to 15 of 15
Thread: Catalytic Converter and Diesel
    VT V6 Executive 98
    Jul 2008
    Alice Springs NT
    Default Catalytic Converter and Diesel
    I managed to get some free fuel but the fuel has some diesel in it.
    Would it hurt the Catalytic Converter or any other part ?
    Appox mix of 40 litres unleaded and 15 litres Diesel.
    It seems to start rough but then warms up OK.
    Maybe I should top up with Premium 98 unleaded ?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Top up with any petrol, it doesn't have to be premium. It will be fine, just be smokey and smelly and run a bit rough until all the diesel has gone.
    Visit my Facebook page
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    Would you drink 40 litres of clean tap water mixed with 15 litres of sullage
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    MY04 VZ SS A4
    Feb 2007
    North Shore, Auckland, NZ
    Is diesel a heaver fuel than petrol? If so, let it sit over night and siphon the petrol of the top ...
    If computers have no doors or fences, who needs Windows and Gates?
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    VXII
    Nov 2009
    Diesel will poison your cat (and O2 sensors), just like lead, engine oil, coolant, silicone and a whole host of other chemicals will.
    (You have to ask yourself though, do you think your cat works efficiently anymore anyway? How many kms has your VT done?)
    Diesel is soluble in petrol and will stay in solution, even when left for a while. It needs to be evaporated to be separated - hence cracking towers and intense heat at refineries.
    Your car will also chuff out filthy white smoke - enough to make the boys in blue take notice. Just think about how little an amount of engine oil needs to be burnt to produce a smokey exhaust.
    I wouldn't recomend it.
    99 VT Sedan
    Feb 2010
    Why on earth would you put that mix in your car??????????????????????????
    I know its free but why would you risk it..?????
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Nothing to risk, it won't do any damage to a cat or an O2 sensor.
    VT Berlina S2 V6 + VZ Acclaim Wagon
    Jul 2005
    For $70 bucks worth of petrolene why bother taking the risk. Just keep it for your lawnmower or something.
    VT V6 Executive 98
    Jul 2008
    Alice Springs NT
    I just topped up with Vortex 95 and the car seems to be running alot better. The reason I used this mixture was because I did not think anything could go wrong.
    Maybe my injectors could get clogged up? Is Diesel thinner than Unleaded ? The car VT 98 V6.
    Before I put the vortex in the car it would rev to just over 1000 revs when i started the car. Then a fex seconds later it would almost stall then come good again once or twice
    When the thermostat opened the car would idle OK
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    we had a customer in at work that had 1/4 tank of diesel in their captiva, and filled up with unleaded by accident.... needless to say that went straight into my old VR SS quick smart! did no damage whatsoever, and didnt even blow smoke.. youll be right mate
    VT V6 Executive 98
    Jul 2008
    Alice Springs NT
    Just dug out my cat about a month or two ago. Due mainly to going over bumps on a dirt road I think.
    Commodore M6
    Jul 2010
    East Coast
  15. #15
    VT
    Apr 2005
    QLD
    I heard they gain power when you run Dot 4 brake fluid through them as well.
  1. catalytic converter
    By vrfireman in forum V6 Development And Modification
    Last Post: 12-02-2010, 04:42 PM
  2. catalytic converter
    By StatOmaN in forum General
    Last Post: 10-02-2010, 10:59 PM
  3. need a catalytic converter in S.A
    By omaz78 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2008, 11:57 PM
  4. Replies: 4
    Last Post: 21-06-2008, 12:40 PM
  5. VX S S/C6 Catalytic Converter
    By MoSkA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2006, 07:35 PM
