Hi all, couple of months ago i purchased a couple of second hand DBA rotors for my VR Stato, they were advertised as a VT brake upgrade for VR-VS, the seller had them on his VS, i never ended up fitting them to my VR stato, (sold it), but when i tried to fit them to my WH stato they wouldnt fit (hub hole too small), so my question is are the VR/VS hub holes smaller than the VT/VX/WH? If so, can they be machined to suit VT/VX/WH etc? Seems to be about 1mm too small, any advice appreciated thanks.
yes the hub centre of a vr/s is 1.5 mm smaller than a vt and onwards unit...sounds like you have the ones made by dba to adapt the vt unit to a vs without shims..usually you have to use shims to make up for the 1.5 mm difference to get the fit right when bolting stock vt discs to a vr/s
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
yes that sounds right, do you know if they can be machined to suit?
anyone??????????? lol
would anyone out there know the correct measurement for the vt disc hub hole?
could find someone in a similar situation that has the correct type for the VT up but was looking for the VR VS shimless type and do a trade.
