I need to replace my CAS in my VT SS 5.7L LS1, where is it located, and how do u replace it? i have the new CAS just need to figure out where it goes
Check out my VP
Wanted to Buy VP Front & Rear Bar/Bumpers
I would assume it would be around the harmonic balancer somehwere.
I just had my CAS replaced the other day, it is located behind the Harmonic Balancer.... you can just see the plug sticking out from behind on the right hand side of the HB.
