Results 1 to 6 of 6
Thread: Piston slap or stuck lifter(s)
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Default Piston slap or stuck lifter(s)
    I have this ticking noise in my LS1 that does not go away I`ve learnt piston slap only lasts mostly from warm to operating temp because of the various expanding rates of all the materials used, mine stays like it all the time has anyone had piston slap that did not go away?
    bf xr6 daily, vl project, wb ute project
    Aug 2008
    QLD
    How many thread does one question need?
    Quote Originally Posted by vn_v6 View Post
    be A SIICK ****, and weld ur exhaust to your body, that way when u drive, people wont think your exhasut or motor is stock cus it will vibrate and be loud, and be cool
    vx berlina wagon 5.7
    Feb 2010
    Bendigo, VIC
    yeah my vx does that, thicker oil helped a bit but its still there, 2 mechanics have told me not to worry about it as its fairly common, i dont believe its piston slap though, if i ever get alot of money i'l get it looked at further
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    You could just have noisy lifters. The springs get soft over time and it doesn't hurt to change them.
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    VS SS
    Mar 2009
    i used to have a vt valais LS1 with the same problem, turned out to be a buggered valve spring
    vt/vx ls1
    Jul 2009
    I have found out it could be many things...my advice get it checked properly eg holden dealer, could just be valvetrain wear (which wouldn be so bad )or could be oil pressure or flow problems (which wont take long before evrything goes bad... i wouldn overlook this!!!!!!!!!! i had the same problem too, my approach-rebuild, im not finished yet i only just got the motor on the stand tonight but iv got new bearings, rings, oil pump, comp lifters, springs, cam n rods, y/t rockers, timing chain, bolts n gaskets, ill get cam bearings pressed in by shop along with hone and ill do the rest myself..
  1. Piston Slap
    By pikey in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-12-2009, 07:17 PM
  2. piston slap in vy gen3?
    By cpbait in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-08-2008, 01:49 PM
  3. piston slap
    By buggzy in forum LSx Development and Modification
    Last Post: 13-03-2008, 09:35 AM
  4. Need Help With Piston Slap Probs
    By BUNDYSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2006, 03:33 PM
  5. Piston Slap in VZ range. Yay or nay?
    By ssz-250 in forum General
    Last Post: 03-01-2006, 09:07 PM
