Results 1 to 8 of 8
Thread: engine oil in radiator
    acclaim VT 2 V6
    Apr 2010
    Default engine oil in radiator
    Hi.I have seen similiar posts refering to trans oil in water but this is engine oil.VTII V6 auto commodore app 190,000K.Blew top rad hose and when replacing coolant noticed small oil globules rising to surface when running motor.Checked cap and found deposit there.Checked res dipstick and found clump of oil on it.(btw engine didnt overheat with failed hose as it blew instantly).Removed and cleaned res container and ran car.Small smear of oil on cap after running.
    Do I need to panic at this stage or is there an explanation for oil getting into the coolant.Have owned the car 8 years and havent seen this before.Would the catastrophic failure of the top hose created a shock to the coolant system that may have sucked oil from somewhere?I am told head gasket probs arent common with these?(hoping)
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    head gasket you would have coolant in the oil, so i would be checking under the oil cap.
    But the way you describe it, sounds like an inlet manifold gasket to me. Mine does the exact same thing, you probably found the thread i made when i thought it was tranny fluid. Around a $300 fix from a mechanic. Not too hard for the DIY man either
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    I don't really know VT V6's, but I'm guessing they about the same as VS Ecotec's, but it's 'possible' it's the manifold gasket which has blown, and where the oil is possibly getting in to the cooling system, could also be getting some coolant in your oil too, check your engine oil after the engine has been running, see if it's got any light milky, coffee kind of colour in it.
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    acclaim VT 2 V6
    Apr 2010
    Sorry, forgot to say that I drained the engine oil to check and found no sign of water.So sounds like the valley gasket.Any damage done if left awhile?
    Thanks!
    BoNeZ-01's Avatar
    Mar 2010
    Well, if oil is getting in to your cooling system, then it's possible air could too, and that's not good.
    Plus the oil would be changing the properties of the coolant, so that it might not work as good as it should.
    'May' be ok to drive for a few more days, short drives, but I'd be getting it fixed as soon as you can, just in case.
    VT S-Pack 3.8L Supercharged - Rebuilt*
    Feb 2010
    If you have a valid reason for requiring my location, you can ask!
    as far as i know the VS engines are virtually the same as the VT engines so following these instructions should be fine
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    if you haven't got any coolant in your sump, i would add some radiator sealer(some thing like silver seal or cargo seal) to your radiator. this will seal up any minor leaks. had the same problem with mine and it seems to have fixed it.
    acclaim VT 2 V6
    Apr 2010
    Thanks guys.
  1. VT engine/radiator heat help
    By Gokz777 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2010, 11:15 PM
  2. Radiator changed & flushed, now rough idle, blowing white smoke & coolant on engine.
    By MizzVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2009, 07:10 PM
  3. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  4. Engine Oil In Radiator
    By pedrod59 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-07-2009, 11:02 AM
  5. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
