Results 1 to 8 of 8
Thread: Engine turned itself off!
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Default Engine turned itself off!
    Car VT II V6 auto.
    I'm a stickler for warming cold cars. Yesterday i warmed the car for a few minutes and started to reverse out. About half way down the driveway steering straight the car died without warning. No warning sounds, no missing or any reason to suspect what was about to happen.
    Has this happen to anyone before ?, is this common or an underlying problem what's everyone's thoughts ?.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Did it fire up straight away or is it still not going?
    You can check the codes the same way as the VR/VS by shorting pins 5 and 6 on the ALDL connector and counting the engine light flashes.
    Visit my Facebook page
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Fired away not a problem.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I'd check the codes first and see if one has logged, then go from there.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Ok thanks for your help.
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    I am going to have to check my codes as well my car has done the same thing within the last 1500km at least 4 times all my dash board lights come up and the car shuts down then starts fine.
    VX Executive S2
    May 2006
    Frankston South Vic
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by lout View Post
    oil pressure sender on the way out
    Would that sender cause a hesitant start up ?. Would it also give the feeling of a slight flat spot.
  1. Engine Light Comes On When Key Turned To ACC
    By freddyfinn in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-12-2009, 03:57 PM
  2. fan stinks after A/C is turned off. why?
    By Caprice5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2009, 10:42 PM
  3. car just turned off ??
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2008, 06:17 PM
  4. amp cutting out when turned up
    By Burnout_bro in forum Car Audio
    Last Post: 09-02-2007, 03:02 PM
  5. VT S Pack engine fans keep running after car is turned off.
    By Cashy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2006, 08:24 PM
