Results 1 to 7 of 7
Thread: Help - dash and parker lights fuse keeps blowing
    vt berlina
    Feb 2009
    Default Help - dash and parker lights fuse keeps blowing
    Hi the dash and parker lights fuse keeps blowing on my VT , I have tried replacing the fuse with a higher rated fuse and it worked for a while but now it just blows everything I put in it , even upto 30a..
    Any ideas?
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Could be water getting into your tail-lights and causing a short. Mine was doing this
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    There is obviously a short somewhere but I can't really say where, but I can offer advice about putting in higher rated fuses as this can cause serious damage to the wiring. Fuses usually blow because of a short so the best thing to do is find the problem.
    MY RIDE
    VT Berlina S2 V6 + VZ Acclaim Wagon
    Jul 2005
    HAHA I had this exact same fault on my old HX kingswood. (remember those cars - everyone used to have one!) Mine was just the wire for the number plate light shorting onto the chrome bumper. Doesn't really help you sorry but I just reminded me of driving home with my high beams on the whole way cos thats the only way I could get any lights on.
    VX Lumina V6
    Feb 2010
    Agree with the above posts; you have a wire shorting out somewhere probably the park lights or maybe the number plate. Needs a very close look to find it most times. Don't put a heavier fuse in; this can cause the wiring to heat up and set fire to your car - you have to find the cause
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by jtunes View Post
    Any ideas?
    Check for water or excessive moisture in every bulb/globe socket housing,spray'em with W40/CRC.
    Next time solder a 40Gauge copper wire!!!!!! You'll never have any more probs with the car,ever .
    vt berlina
    Feb 2009
    Thanx for the replies guys, I have been all over the obvious points like water in the tailights , numberplate shorts .... I have found that one of the Parker globes in the headlight is out... Would this be causing it.... I have put fuses back in to see and they will work die an hour or so sometimes and blow ... Where as before they would blowas soon as I put the lights on.
    I will get a new globe today for the Parker in the headlight .. Hopefully this will do the trick..
    Cheers j
  1. Fuse for the dash lights keeps blowing
    By cypher967 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-06-2009, 07:09 PM
  2. After pulling dash apart, indicator fuse keeps blowing
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2008, 06:11 PM
  3. Blowing fuse VS V6
    By TrustNo1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2008, 04:48 PM
  4. stereo and dash light fuse keeps blowing
    By V8commodore_chick in forum Electrical Wiring / Questions
    Last Post: 21-07-2006, 02:03 AM
  5. Dash Lights/Shift Indicator Fuse Blowing?
    By svs500 in forum Electrical Wiring / Questions
    Last Post: 29-11-2005, 03:38 PM
