Results 1 to 12 of 12
Thread: reseting vt airbag light?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default reseting vt airbag light?
    can u reset the air bag light with my laptop? i have one of those diagnostic cables from ebay, can this work? if so how
    thanks
    VT S-Pack 3.8L Supercharged - Rebuilt*
    Feb 2010
    If you have a valid reason for requiring my location, you can ask!
    i wouldn't have a clue...but wouldn't you need the correct program on your laptop if it was in fact possible. it would be good to know coz just for a few clicks it costs like $70. BUT if your airbag warning light is on then there means that there's a fault and might not deploy in an accident and could cost you dearly. so it might be a good idea to get it checked out. i know mine's faulty. had it reset once and a year later it came back...didn't bother getting it reset and then one day it just stopped LOL.no more airbag light and no more beeping lol...i won't complain...
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    ah ok, lol i made the mistake of starting teh car with no airbag, :P thats y its on hahah
    cheers
    vt exective
    Oct 2006
    My airbag light comes on aswell i started the car when i had one of the front seats out opppss .i havnt been to worried about it but last week i had a smash hit a truck up the rear at about 15 kms hour ,smashed the front of the car and the airbags should have gone off but they didnt ,i guess cause the airbag light was on ..... something to think about ....
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I could be wrong but I don't think 15 kph is fast enough to set off the airbags.
    MY RIDE
    vt exective
    Oct 2006
    my front bar was smashed the bonnet was smashed in it has a big fold in it and the bar behind the front bar the INTRUSION BAR was smashed aswell it was pushed in just missing the radiator ...
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    yeh 15kph is way to slow for them to go off, the gregoreys say that it will go off over 30kph anything less and there desighned not to.
    i know u may think "y the hell wont they at that speed (15kph), its cause they go off with a massive amout of pressure and i for one dnt want then going off if i hit sumone at 15kph, that would be ouchies and a wast of an air bag (very expensive)
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    Yeh 15k is way too slow, yes the impact would have been hard but nothing as near as if it was at 50 or 60+ k's. At 15 k's the airbag would likely cause more injury than the actual crash.
    VXII
    Nov 2009
    SRS systems don't depend on speed of impact to deploy, they use accelerometers in the car to detect acceleration rates. (FYI acceleration is the term used to describe a change in speed, both faster and slower).
    It is possibble for the airbag to deploy when you are parked and ignition on, when someone drives into you from the front.
    Most DTCs have a self-reset function built in. For example, if no fault is detected after 255 key starts, DTC is deleted from active/current code memory, but stays in history code memory, and warning light switches off. This is why your airbag light switched off after a while.
    All SRS functions are disabled when the warning light is illuminated. This is a safety feature to minimise risk of false deployment when a fault is detected with the system.
    VT SS 5.7
    Mar 2005
    Goulburn
    what do you think the holden dealer would charge t reset the airbag light?
    Real cars don't power the front wheels, they lift them
    99 VT Commodore
    Mar 2010
    south east queensland
    mines on also in my VT....beeps on starting the car then no beeping afterwards, but the light is ALWAYS illuminated!!
    99 VT Acclaim
    May 2006
    Traralgon, Victoria
    The cost to reset depends on the situation. If it's a case of hook the tech2 up and it just needs a reset, then it will not cost much, but if it's a case of hook the tech2, it shows a bunch of problems, then it will cost you more
    EDIT
    Also you can't reset with a cable bought from ebay. They're can be used for diagnostics and that's about it I think. You can't do any programming
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. vt airbag light
    By adamandtanya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2010, 06:06 PM
  3. >Need help< AIRBAG LIGHT
    By DND in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2009, 11:16 AM
  4. SRS airbag light is on!
    By bedo2405 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2009, 10:42 PM
  5. vt airbag light
    By dcjacko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2009, 03:54 PM
