Results 1 to 4 of 4
Thread: VT SV6 starting problems
    geebee Guest
    Default VT SV6 starting problems
    Hi all. I've recently purchase a VT series2 SPak Supercharged, On occasions I'm having trouble starting. There seems to be plently of spark and grunt from the battery, it seems that it floods after 2 or 3 cranks and you get a smell of petrol, then when you floor the accelerator it will fire up. This can happen when the car is hot or cold, but not all the time. Any ideas would be great.
    vtchick Guest
    I had a similar problem but mine was only when warm/hot. It would take a bit to turn over, start when u touch accelerator and then idle rough for a bit. Turned out to be my crank angle sensor?! But ur's could be a number of things i guess.
    r00ns Guest
    geebee Guest
    r00ns
    Car is not on gas, I run standard unleaded. gb
  1. Problems starting a VK 3.3 EFI
    By 2_SeeK_U in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-09-2007, 09:13 PM
  2. VR V8 starting problems
    By jasonb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2006, 11:54 AM
  3. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  4. vn starting problems
    By driver in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2005, 09:42 PM
  5. Starting problems
    By Chris in forum General
    Last Post: 30-06-2004, 09:17 PM
