Results 1 to 5 of 5
Thread: Radiator issues
    vex
    vex is offline
    vx s2
    Jun 2009
    Default Radiator issues
    hey guys,
    car has been overheating but the temp gauge says everything is ok. about 5 mins after starting the radiator starts steaming, and is really hot. the radiator cap does not heat up at all. there also seems to be a leak from down the top right hand side. any ideas?
    VX Executive
    Feb 2008
    have your car towed to a decent mechanic to see where the leak is coming. You might have developed some pin hole leaks or hairline fracture leaks which cannot be seen unless they pressure test the radiator. there also the water pump, hoses, heater and thermostats to check. Whatever you do, dont ever drive the car as the temp sensor might be faulty or registering only the temp of the coolant reservoir. If steam is coming out from your engine bay, then its really bad news. i learnt my lesson too late and it cost me a brand new engine and a brand new cooling system.
    vex
    vex is offline
    vx s2
    Jun 2009
    vt berlina series 1
    Sep 2008
    leak is on drivers side or passengers? saying right side depends on which way ur looking at the car , if its drivers side , it could be the heater tap which is near the firewall end of the engine bay on drivers side , its stuck on the side of the wheel arch is the easiest way to say it , , one of the pipes on the heater tap usually crumbles and breaks , its a $25.00 part easy fix , or it could be the inlet tank on the radiator as these are the most common to crack m failing that look at the water pump and see if you can see any stains around it , in fact loook for the stains in the places i told you and come back here or see a mechanic if unsure
    vt berlina series 1
    Sep 2008
    or as you said it could be the cap not holding pressure and blowing all the coolant into the overflow bottle , which is on the pasengers side
  1. Coolant / radiator issues.
    By the_duke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2009, 05:50 PM
  2. Help needed radiator issues
    By Slugnlettuce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2009, 08:10 AM
  3. Radiator/Coolant issues
    By the_duke in forum V6 Development And Modification
    Last Post: 07-03-2009, 11:02 PM
  4. Ebay Radiator Issues
    By Riff88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2007, 11:37 PM
  5. VS Radiator Fan issues
    By zuluchief in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-08-2006, 07:03 PM
