Results 1 to 8 of 8
Thread: Breaking steering lock
    Mar 2008
    Default Breaking steering lock
    Hi all, the steering has locked on my vx for the 2nd time in the ignition barrel, and unlike when it did so yesterday, no amount of wriggling of the wheel turning of key or bashing helps.
    My question is, if i do the old jam a screwdriver through the barrel to break the lock, will it still recognise my key and turn over afterwards, or will it no longer recognise the key and not allow the engine to start.
    I will need a new barrel if i do this, but seems i will anyway
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If you damage the barrel you will have great difficulty removing the barrel to replace it because the key needs to be in the ON position to remove the barrel. In my opinion you will damage the barrel and you won't be able to get the key in it anyway.
    MY RIDE
    VY Berlina V6 / R31 Skyline
    Dec 2008
    you can snap the steering lock by getting you and a few mates to hang off the steering wheel, giving it a good yank downwards
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VT Berlina S2 V6 + VZ Acclaim Wagon
    Jul 2005
    I think the first thing i would be doing is spraying an aerosol cleaning solvent into the barrell, so it is completely flooded, hopefully flushing out anything that may be in there, followed by a good qualilty lubricant. Jaycar sell some good electronic cleaning solvents and lubes. Oh yeah, probly best to disconnect the battery first!
    Surely its got to be a case of a pin just not moving freely? Sounds like a better option than brute force to me.
    Hey, maybe Locksmiff would know what to do is he reads this post?
    Mar 2008
    Thanks for the replies, i havent resorted to smashing the barrel yet luckilly.
    If i was to snap the pins by forcing the wheel, would the barrel then turn so the car can be started by my key?
    Mar 2008
    Well finality, i got a old club lock from the garage, clamped it on, and stamped down with all my force, i seem to have snapped 1 of the steering lock pins. now i can move the wheel enough that i can get the key turning and start the car. and the steering also locks
    VX Executive S2
    May 2006
    Frankston South Vic
    moral of the story you should have fixed it yesterday
    VT Acclaim Wagon
    Oct 2008
    pain in butt way to avoid this is to pull the steering wheel off, remove combination switches then clean and lubricate the steering lock pin and housing with the correct grease. it is possible to buy spray grease which makes the job a little bit easier. Should be done every 2 years or so but nobody I know does it.
  1. ignition/steering lock problems passenger door lock
    By timbuk3 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2010, 08:21 PM
  2. How do i break my steering lock??
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2009, 03:47 PM
  3. Steering Lock
    By Ardavast in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2006, 07:11 PM
  4. steering column key lock Help
    By sherr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2006, 08:11 PM
  5. vn steering lock
    By rattattack1313 in forum General
    Last Post: 16-03-2005, 06:01 AM
