Results 1 to 6 of 6
Thread: Changing power steering hose
    scbh81's Avatar
    scbh81 is offline VRUUUM XU6 180 SC
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Default Changing power steering hose
    Hi guys,
    My power steering hose that goes from the reservior to the pump is leaking at both ends. Do i need to take anything into consideration when changing the hose? Can i just remove the current one and replace it just like that? Do i need to bleed it or anything or anything else like that?
    Any help and advice would be much appreciated!!!!
    There is no such thing as 'What if?'
    http://forums.justcommodores.com.au/...y-hsv-xu6.html
    VT II supercharged s pack and VY lumina
    Jan 2010
    hey mate
    think you should be all good to simply replace it, but when u are fill it, hold the reservior as striaght as possible relative to the bottom hose connection and fill it up slowly so the air thats in the new hose excapes.
    never done it on a vr sc but cant imagine it's too much different to vt sc.
    the hoses im pritty sure is low pressure
    scbh81's Avatar
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Cheers so much mate
    Do i need to remove the reservoir in order for it to be straight? cause with it fixed there is like a bend in the hose?
    BTW it IS a VT SC
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    mine was leaking a bit at the top, so i released the hose clamp and re clamped it on the part of the hose that wasn't squashed from factory. You should be able to get almost the whole width of the hose clamp and it creates a good new seal, without having to replace the hose. I reckon it worked for me fine.
    scbh81's Avatar
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Quote Originally Posted by jazza15 View Post
    nice one i will try that and see if that works mate. Cheers for that
    Jan 2010
    long day mate didn;t see that it was an xu6.
    yer if u still need to replace it, you'll have to remove the reservoir, it's held in to the braket with a clip like attatchment, it can be pritty brittal because of the heat so might want to be careful, otherwise you can take the bracket off form memory it was only like 3 8mm bolts. i remember doing it when i was replacing the radiator and had to remove the thermo fan shroud,
    hope that helps mate
  1. Return Power steering hose
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-11-2008, 08:45 PM
  2. Power Steering Pump Hose
    By Meerkat in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2007, 03:53 PM
  3. Pressure Hose on Power Steering...
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2006, 11:02 AM
  4. Power Steering Hose
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2006, 03:02 AM
  5. Changing power steering hose.
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2005, 02:39 PM
