Results 1 to 8 of 8
Thread: Is It the alternator?????
    98VT Commodore SS V8
    Apr 2010
    Default Is It the alternator?????
    On the way to the petrol station 2day the battery light was on..I got my petrol then it wouldnt start..I managed to have it jump started...we got about 500m down the road then nothing would work ie: speedo, petrol guage,temp guage, stereo, electric windows..then the car felt like it wasnt changing gears, then it started puttering out and knocking noises were coming from the engine...we JUST made it home and it just died! Last week I have the waterpump and the idle bearing repaired...I do hope its nothing too major
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    it could be the altonater not generating enuf power yes
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    Apr 2010
    Oh sweet..I was just worried that with all that went on it might be a whole heaps of problems..but do you think they are all symptoms of an alternator thats shat itself???
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    mmm check your battery, terminals aswell, check everything to do with alternator before forking out for the wrong part
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VT Berlina S2 V6 + VZ Acclaim Wagon
    Jul 2005
    yeah, could be as simple as the regulator. I havent pulled it out on my VT but i'm guesing it's like most cars and is easy to get to. Usually two screws and then pull it out of the alternator.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If you really want to know for sure, take it to an auto electrician and they can tell you in a couple of minutes, it won't cost much and it could cost nothing to check it.
    MY RIDE
    Dec 2009
    Quote Originally Posted by BerlinaBen View Post
    Check the voltage on the battery terminals withthe car running it should be about 14.2 to 14.4 volts, if it is then the alternator is probably not the problem. Check all your wiring next.
    Make sure you disconnect the battery before you take the regulator out. Usually it will be the brushes worn out and you can either buy a new regulator or just buy brushes and solder them in, about $10.
    Auto elecs wil try to selly ou a whole reco alternator, se eif you can get brushes first and try that or another regulator.
    Apr 2010
    yeah it is the altrnator...getting it done today...costing about 385 for the alternator +80 for labour...damn!!!! thats coz its a v8 5.7L!!!!
  1. I need a new alternator.. What if....
    By PUSHIN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2010, 01:03 AM
  2. vr alternator
    By gottavr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2009, 11:05 PM
  3. Alternator ? Or something else
    By omaz78 in forum Electrical Wiring / Questions
    Last Post: 23-06-2009, 10:01 PM
  4. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  5. Alternator going?
    By squidda in forum Electrical Wiring / Questions
    Last Post: 29-03-2006, 06:35 PM
