Results 1 to 3 of 3
Thread: VT II 120km service questions
    VT
    Feb 2009
    Default VT II 120km service questions
    Got my first service coming up (bought it at 114k), so just wondering is this a major one? Any ideas how much it would cost with no major problems?
    Is there anything I can do to make it a bit cheaper, as in do the work myself?
    My breaks are making a squealing noise when I apply the breaks, and I am told this is the normal mechanism to let the driver know that the break pads need to replaced?
    Also, my aerial is broken; it does not go up or retract when the car turns on. It is currently just permanently up. Is this something easy to fix? There is nothing wrong with the reception.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    I am using a VS handbook but for it a 120,000km service includes:
    Change oil and Filter
    Check fluid levels: brake, clutch, power steering, auto transmission, washer. Check coolant inhibitor % with tester and check level.
    Check battery electrolyte
    (V8) Check condition and tension of all engine drive belts using gauge
    Check for signs of deterioation and/or leaks from engine, fluid reservoirs, air ducts, all hoses and clamps
    Vacuum check for PCV valave operation
    Replace spark plugs
    If you are handy with a wrench and socket set you could actually do all this yourself.
    Sqealing is an indicator of low brakes or it could be just dust or glaze over the rotors. If you do get it serviced then get them to check the brakes.
    Regarding the antenna it is most likely that the plastic "rope" that inside the aerial has broken or worn out. You will need to buy a new rope and fit it (or once again get the guys to do it if you take it to be serviced).
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    All depends on whether or not you have the service history. Air filter, fuel filter, plugs should be replaced every 20,000 IMO. Probably could do with a diff oil change and auto fluid and strainer changed, too. All easy to do yourself if you're mechanically minded. Best of luck, mate either way.
  1. few questions regarding 90,000 service
    By Harrison in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-02-2010, 12:34 PM
  2. service questions
    By tiersum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2009, 07:11 PM
  3. Service Questions
    By Tis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-07-2009, 09:26 PM
  4. A few questions before i do a major service...
    By lkorruptl in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-03-2009, 01:31 PM
  5. Exhaust/Service Questions
    By CMI83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2005, 01:09 PM
