Hey guys,
I'm getting this higher pitched whirring noise from the engine. Sounds like one of the belts/pulleys. It's not low power steering fluid because it's not only when turning, it does it on idle and gets louder as acceleration progresses. Any help appreciated.
Cheers.
My VX had that same problem, as you get faster the sound gets louder???
With mine it was the idler bearings, the actual bearings on the rollers of the pulleys, Its like a hundred or so bucks to get fixed.
Then again it might not be that, but my guess would be that, nothin too serious.
Best thing to do with the belt on and car running use a long screwdriver (CAREFULLY) touch each drive belt pulley and see which one is making noise. also check alt, P/S, A/C & water pump as well as these can also be noisy... Another thing to do is remove belt start and run the car for a few sec and if the noise has gone then it will be the one of the pulleys..
