Results 1 to 12 of 12
Thread: drivers seat plastic trim
    kazalex's Avatar
    kazalex is offline karen
    red vx series 2 commodore
    Oct 2008
    adelaide
    Default drivers seat plastic trim
    Hi my drivers seat plastic trim in my vx series 2 ,the plastic part that is held on with a screw has broken and apparently there is no way of fixing it? only to replace the whole thing.
    It is the trim that has the electric seat knob etc.any one fixed theirs?
    VZ Executive
    Dec 2008
    When I bought my new leather seats from Holden for my VZ I bought that exact part for for the existing cloth seats as it was cracked before I sold them. From memory it was around $50+ It's definatly replaceable! If not at your local dealer try the wreckers they should have one.
    Couldn't be without my Commodore
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Just had same prob with the VY. It broke where that one screw holds the entire side seat trim on. Well I fibreglassed it, doing it properly, spending hours on it, etc. Anyway two days later and it has let go again-DOH! I might try and do the same thing again but spend MORE time and effort and see how she goes, otherwise it'll be Holden parts department, DOH! again. The wreckers where I am don't have anything later than VT/X and they've been stripped bare.
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    i zip tied mine to the chair frame...been sweet for 6 months now! bit of a pain to get it tied down properly though!
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    ok, so basically if your trim is the one i have pictured and is the same. there should be 2 holes at the top and bottom of the main hole which is normally covered with a clip-in cover. pull the trim out slightly and thread an appropriate sized zip tie through these holes. then the hard part is getting it connected to a part of the seat frame and getting the zip tie "tied".
    hope this helps slightly.
    Attached Thumbnails Attached Thumbnails drivers seat plastic trim-dsc01764.jpg   drivers seat plastic trim-dsc01765.jpg   drivers seat plastic trim-dsc01767.jpg
    kazalex's Avatar
    Oct 2008
    adelaide
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by drift-it View Post
    Good thinking, I'll give this a go, too. Stuff the fibreglass!
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    coug's Avatar
    coug is offline gotta love the v8
    02 vx ss
    Jan 2010
    buy a new one from wreckers or ebay, just easier and looks better than a repair job. i picked one up from ebay for bout 50 bucks
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I did the zip tie trick, worked well, bumped up the thread for gary
    ewt
    ewt is offline
    VT Wagon & VZ Berlina
    Mar 2010
    Sunbury, VIC 3429
    i just used a metal cork cap of a wine bottle with a loger screw and made a new front bracket
    been like it for two years now
    2000 VT S2 Olympic Ediiion
    Feb 2010
    Basically the reason it happens is the foam has gone to shit and when u put ur weight on the right side of the seat the plastic hole where the screw sits closest to the steering wheel will snap. From my opinion you are better of zip tieing it as if you replace it new or second hand due to the shit worn foam in your seat it will keep breaking i went through two of them before i woke up to myself so dont replace it unless you are getting a new seat and if you get a new seat you wouldn't need one basically just zip tie it. It should have been rectified by your model as it is a common problem with the vt usually a model should have common problems like this fixed by the series 2 model but stupid expensive Holden have just carried on the problem throughout three friggen models. Its a joke. Good Luck.
  1. VZ SV6 Drivers Seat Plastic Bit
    By matt-chops in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-11-2011, 07:38 PM
  2. cracked drivers seat trim on VE Berlina
    By Astranomical in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-07-2011, 09:56 PM
  3. Best way to paint vl berlina plastic trim
    By vl_2010 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-12-2009, 10:07 PM
  4. vn door trim plastic lock
    By 1990vnwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2007, 11:54 PM
  5. WTB VP rear window top plastic trim
    By calais_cruzin in forum Swap / Wanted to Buy / Trade
    Last Post: 28-02-2007, 12:33 AM
