Results 1 to 3 of 3
Thread: VT V6 running rough after intake service
    VT Berlina
    Jan 2010
    Default VT V6 running rough after intake service
    I have just changed the intake manifold gaskets and exhaust manifold gaskets on my series 1 vt v6 and she is running very rough when put into gear and driven almost like on 5 cylinders. I cant find any leaks from the intake or exhaust, all vaccum hose are on, and no error codes.
    Also i forgot to plug the passenger side oxgen sensor back in didn't get an error message, just 12 over and over, is this normal? I thought this wiuld have triggered an error message.
    I am pretty sure i put all the injectors/fuel rail back together properly, altenator, drive belt etc..
    I have little experience working on cars, only done a few things, what can i test/try to find the problem??
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    hey mate
    did you check that all your spark leads are in properly? you might have hit one while doing the gaskets, also if you unplugged your MAF did u make sure is plugged back in?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VT Berlina
    Jan 2010
    hey,
    yeah i removed all of the spark plug leads when doing the gaskets, numbered them and put them back, also MAF is back in and the wires plugged back in.
    I might test the leads with a multimeter to see if they r screwed??
  1. vt rough running
    By Jaybee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2009, 04:37 PM
  2. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  3. Help! VL running rough
    By charlene in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-11-2007, 07:12 PM
  4. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  5. VR ute running rough
    By FREESTYLE_MX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 11:56 PM
