Results 1 to 5 of 5
Thread: vt auto power button and front hub Q's
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default vt auto power button and front hub Q's
    i have a vt executive auto 199 etc...
    anyway when i push the power buttonnothing happens...like the light does com on but the gear box dont change the revs or anything it just stays teh same.
    also how can i tell if teh front hubs need replaceing, wen im going round a bend (mainly a left bend) theres a whooping sound from teh front could this be worn hub bearings? if so how do i know which side??
    cheers
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Pressing the power button doesn't change the revs when it's pressed but it will change gear at higher revs.
    MY RIDE
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    ah ok, so t dnt change at all? in my vs wen power button is engaged the revs change and wen its not engaged the revs change back o normal
    did they change the way it works in teh vt?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    also at 100 the revs re about 1950-2000 rpm....this sems a bit hih however it does need a auto service so this mite be the cause?
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Thats sounds a bout right mines just a tad under at around 1800rpm aprox wat ur gettin neways and at 110 just under 2000rpm. The power button basically revs out n holds the gear its in 4 longer ay, its really only good 4 towing so u dont get the sudden gear changes wen u dont need them...
    Speak 2 greenfoam on this forum since urs is a VT u can get the gears changed via the memcal if thats wat ur after??
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  1. Eco/Power button
    By JSTCOZ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2010, 07:38 PM
  2. the Power Button
    By ramzisleiman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-12-2009, 03:07 AM
  3. power button
    By Junny in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-02-2009, 10:10 PM
  4. Power Button !!!
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-06-2006, 02:33 PM
  5. power button on the auto stick
    By dan_man31 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-02-2005, 06:51 PM
