Results 1 to 6 of 6
Thread: Heating issues
    VXII Executive
    Apr 2010
    Default Heating issues
    Hi everyone,
    Having some major issues with my VXII 02 commodore,
    Had the radiator replaced as well as the themostat as it was always "hot hot hot" it would go back to normal and be fine, turns out the radiator was rusted and leaking.
    So that's been fixed, last night temp goes to Hot and I can smell the antifreeze, get the car home, and today drive home from work with it hot all the trip home, fans full bore for 5 minutes after turning it off.
    Looked at the fluid level, seems full. Noticed on the left side of the engine bay everything is coated in a white substance, I can also hear hissing. I moved the car back and saw the white drops on the driveway as well.
    It is going to the mechanic when it can, wondering if I should try to drive it there or get it towed, Anyone have some thoughts on what I might be up for?.
    THanks
    VX 5.7 A4
    May 2009
    Mabye your water pump is fualty thats why the tempruture is hot
    and white substance means your engine is mixing coolant with engine oil
    check you engine oil dip stick if it is white that means its mixing
    dont start your engine our you will damage
    that mean the head gasket is bad and allowing coolant to enter engine
    vt s s1
    Mar 2009
    the white stuff is most likely coolant burnt up, if it appears osrt of frosty if that makes sense.
    If so this means you are leaking coolant. Have a look round any hoses you can get your eyes on to see if you can spot a leak.
    When you checked the level was it shorty or just after you turned the car off? Often when checking and the car is still hot enough fluid will stay in the radiator and make it "appear" full.
    Dec 2009
    Left hand side as looking from the front (drivers side)? If so check the heater tap and the O rings where the heater hose barbs go into the motor. The white stuff is evaporated coolant residue.
    VXII Executive
    Apr 2010
    Just to let everyone know it was the heater tap, mechanic came and fitted for $200.
    '98 V6 VT Berlina
    Nov 2009
    Wow, sorry dude you got ripped. Heater tap is about $35 and 15 mins of work.
  1. heating issues vx need HELP solving the problems
    By vx2000 in forum General Discussion
    Last Post: 05-01-2009, 11:03 PM
  2. heating issues
    By 5lt caprice in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2008, 03:49 PM
  3. vk heating
    By madamd in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-05-2006, 01:46 AM
  4. Heating help
    By Holden_Mechanic in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-11-2005, 06:21 PM
  5. over heating vs
    By bucko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2005, 12:43 AM
