Results 1 to 4 of 4
Thread: Sticky ignition key
    2002 vx wagon
    Mar 2009
    Default Sticky ignition key
    How do I replace the ignition switch on my vt. Its sticking on and I am worried that it may damage the starter long term.
    Is this something I can do simply??
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It sounds like the spring in the switch has broken. It's not as easy as it should be to replace. First you must remove the barrel (do a search for that info) and then the removal of the switch is easy.
    MY RIDE
    VX Executive
    Feb 2008
    Its the first sign that the ignition barrel is on its way out. A brand new ignition barrel should just let you slide your key in (sounds like "SSCCHH-LICK) and no problems in pushing the contacts for the ignition switch. I had mine replaced as the alloy part of the ignition barrel had broken off clean at the top and the key was just spinning but not activating or touching the ignition.
    It isnt a DIY to be done at home as you would have to removed the steering column and deal with torx screws which are holding onto the barrel attached to the steering. Cost bout B$150 brand new for me
    vt s s1
    Mar 2009
    i replaced my ignition switch without removing the barell or steerig column
    Just trying to think back what i had to do.
    Shroud off, should be one very small alan key bolt to undo (i used a small flat head screw driver to undo as wasnt that tight)
    Remove all wiring from it
    "SHOULD" then slide out, i emphasise on should as mine didnt. My memories a bit vague so fogive me if its not 100% right but you may have to fiddle with different positions of the key to get it to slide off.
    Then just pop the new one back on again you will need to fiddle with key positions.
  1. sticky box
    By stewy10 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-03-2010, 01:01 PM
  2. Sticky gauges
    By chrisdoesitbetter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2009, 07:57 AM
  3. Sticky ignition
    By joe_rolls_commo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2009, 12:35 AM
  4. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  5. sticky Ps
    By Tom04 in forum General
    Last Post: 16-11-2006, 03:34 PM
