hi guys,
Very unusual problem. My car wont start sometimes. Its really weird cause i can't pinpoint when it does. Just random. It turns over put just doesn't start. Its like trying to start it with no fuel in it. What i need to do then is switch everything off and wait for like 5 mins and bang start on the first turn.
Any ideas whats going on? It has probably happened like 4 times now in the last 3 months.
any help and advice would be great!!!!!
Fuel pump? or clogged injectors or your plugs are fouled?
When it does not start check for spark. Can you here the fuel pump load up when the IGN is on?
If there is no spark could be coils,DFI module,CAS.
Also check the EFI relay and injector trigger obviously with the car not starting
Hey mate,
Looks like you know what your talking about...
Sorry but how do i check for spark? Do i remove a lead?
and Fuel pump load? do i need to listen to a specific sound?
What am i looking for when i'm checking the EFI relay and injector trigger?
Cheers so much for your advise!!!!
My VX has done this twice of late and I discovered that if I pull the key out, press the button to lock the doors then press the button to unlock, put the key back in and it starts immediately. Someway or other, the immoboliser activates ( buggered if I know how or why) and the starter just turns over but won't fire till I do the above. Give it a try; costs nothing. Hope that works for you.
Hey mate thanks for the tip but mine actually turns but just doesn't start. It's like trying to start a car without any fuel. Just so annoying as it happens randomly specially when i'm in a rush. After about 10 mins of trying it fires and all good after that.
any ideas guys?
Should check the obvious first. Make sure your battery terminal connections are tight and aren't fouled up.
I definately reckon it is key related. As I posted previously, mine would wind over but wouldn't start just as yours is doing. My VX did it again the other day (wouldn't fire, just wound over. Took about 30 minutes before it would start) so as an experiment I swapped to the spare key when I got home as the main key looked rather worn and a bit of a sloppy fit. I have not had a problem since.
I reckon that the immobiliser wouldn't repond to the signal from the key because it is a bit old and worn and even though the key fits the ignition and winds the starter over, it wouldn't release the immobiliser and therefore the engine cannot start. Try this if you have a spare key.
hi dunky & scbh81
Just an idea guys that are the terminals around your ignition located properly. The key must make contact with them of course for it to be immobilised. If its out by 45 Deg, could create intrmittent problem. If its out by 90 Deg, well then she just will start not at all.
Put Both thumbs on the the terminals, push in and rotate anticlockwise until you feel the very fine click. If you cant move it means its located.
Hope this helps
KBELT
dunky
The bateries in the paddlepops have atleast 3-7 year lifespan. Only VRs batteries can be replaced. With VT & VX you have to replace the paddlepop.
If the key is worn on the sides or top or both then it just wont turn and thats when it seems the ignition has shut down.
Thanks for the tip kbelt66. I bet the whole paddlepop costs a fortune compared to a battery! Seems though my spare key is OK for the time being. I also bet there have been a lot of people ripped off by workshops because of this hassle, changing everything under the bonnet when it was a key fault all along.
im a bit late, but i reckon he's spot on about the key. mine dose the exact same thing sometimes, and its the key reader (silver knob) not touching properly. when it dont start the little red security light is flashing.
hey guys,
thanks for all the advice...
Its the fuel pump relay.... I swapped it with the low beam relay and bang the car starts like new..... glad i didn't change the fuel pump. saved a few $$$
My question is if the low beam is working fine with the faulty fuel pump relay, do i need to change it?
its got the same numbers on the side as the other relays.
cheers for all the help guys :-)
if the low beam is working with the fuel pump relay dosent sound like it is a relay problem
Yes i agree......
But when i put the relay back to fuel pump it doesnt work. Maybe the relay is on its way out and the low beam does not need a full strength relay...
its working fine at the moment. Maybe the fuel pump will end up dying anyway....
Glad to hear it was an inexpensive fix. From what you described, it had to be electrical. I'd get another relay anyway and keep it in the glovebox "just in case".
