Results 1 to 2 of 2
Thread: ecotec losing oil pressure under load
    vx calais supercharged vt v6 wagon. vs v6
    Apr 2010
    Newcastle
    Default ecotec losing oil pressure under load
    Seems strange. The car will idle all day and hold 300kpa oil pressure. fans start and stop as normal with temperature of water going up and down but take it for a drive and from cold only takes 10 minutes to get the rattling lifters. Possible cracked heads. Any thoughts.
    10psi boost. extractors, twin cats 3" mandrel bent exhaust big slotted brakes kenwood head deck with 600 watt sub.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Are you sure it is the lifters rattling and not pinging. It could be running a bit lean from a weak fuel pump or blocked fuel filter.
  1. losing oil pressure at idle
    By lowrida56 in forum General
    Last Post: 23-09-2009, 10:10 PM
  2. Misfiring under load after a oil pressure switch problem
    By grim596 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-07-2009, 10:47 PM
  3. VS V6 losing oil pressure
    By Goum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2009, 03:51 PM
  4. ecotec oil pressure?
    By Goose!!! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-02-2009, 06:10 PM
  5. Ecotec losing oil
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2008, 06:35 PM
