Results 1 to 5 of 5
Thread: Help with some fault codes and a ticking sound!
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Default Help with some fault codes and a ticking sound!
    OK for a few weeks now the idle and running of the car has been a bit dodge. Sometimes (more often when cold) the car will drop nearly all RPM when slowing for lights or anything, nearly stall then regain RPM. So today I got an auto sparky to pull up any fault codes, got his:
    P0405 - EGR Position fault
    P1372 - No ref pulses while cranking
    P0101 - MAF sensor out of range
    Now MAF ok pretty important, I will try changing mine with my parents VY V6 one later, hopefully just oil from K&N filter on sensors, as MAF is only about 2 years old. Now what about the others? Might the EGR solenoid be stuck? And might the other one be a failing CAS? It still cranks and starts fine.
    Now the other problem is a ticking sound that I can hear in the cabin. Now heads were done mid last year with engine rebuild, I replaced the lifters about 2 months ago. Might it be a dodgy injector? When I use my auto stethoscope on injector rail its pretty noisy, but that noise may be coming from engine so I don't know. Though I have noticed that ticking sound gets louder when you use more accelerator but RPM doesn't increase. So when I go on an incline and I push accelerator down further but the engine doesn't increase RPM or kick down a gear the ticking sound gets louder, but when it does change down a gear the sound gets softer. Any opinions?
    Thanks in advance.
    Ronald Reagan (1986)
    showbags's Avatar
    showbags is online now Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    sounds like the pipe between the EGR valve and inlet is leaking. that would explaing the ticking noise as well.
    VX Berlina
    Apr 2007
    If the pipe was leaking how would the car sense that? Sounds like a EGR *ahem* 'Support Bracket' might fix that problem. It might not clear the code, but would stop hot, used exhaust gases from entering the engine when it shouldn't.
    VXII
    Nov 2009
    Quote Originally Posted by acarmody View Post
    When the ECU commands the EGR to open and allow, say, 20g/sec of exhaust gas in, it also expects to see the intake air amount (MAF value) decrease by this much. If the MAF value does not change, an EGR fault code may be set.
    It's also important to note, that EGR open commands are usually only given by the ECU during light throttle cruise when the engine is hot, and NEVER during full or high throttle openings. Blocking your EGR does nothing to increase power output at full throttle.
    VX Berlina
    Apr 2007
    Oh I don't expect any power gains, just want a cooler intake manifold. I have a MACE 12mm manifold insulator, but the manifold still get hot.
  1. Ticking Sound
    By VY Rossi in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-04-2010, 06:56 PM
  2. Ticking Sound - Help
    By VOJ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-09-2009, 04:54 PM
  3. 308 ticking sound
    By Disturbed_vegeta in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-10-2008, 09:00 PM
  4. Ticking sound
    By fullymetal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 01:48 PM
  5. VT indicator ticking sound.
    By VIOLETANGO in forum Electrical Wiring / Questions
    Last Post: 08-06-2005, 04:48 PM
