hey
i have recently changed the plugs and leads on my manual vx commodore and since i have done this it misses when accelerating at low revs. i found another thread of the same thing but it had no answer. have checked they are all in the right order n are on properly. any help please?
thanks
have a look at night i bought some new leads once and one of them was faulty you could see the lead arcing right down to the spark plug run the car and rev it a little
check that you did not crack any plugs and resistance check each lead.
No treally because th eengine is not under much load. I had a lead go on my VN and it war running OK, sometimes a bit hard to start other times it started ok and idled and reved in neutral ok it wa sonly under light acceleration up a hil it began to miss and it turned out to be an open circuit spark plug lead. The voltage on the coils is enough to jump the gap inside the lead and the plug when there is no load on the engine. Take the leads off and check with a multimeter ther eis a max resistance as well but not sure exaclty what it is off hand.
Usually a miss under acceleration or uphill (ie under load) is a coil
FIXED
thanks for the help guys, it was a dodgy lead... wasnt connecting to the plug properly. only found it cus there were marks where it was arkin out lol.
thanks heaps.
I was wondering if anyone could please help me! i am about to blow my car up! Iv replaced all the plugs and leads today i put my mates coil pack on mine (he has the same engine) and it continues to miss. Only under slight acceleration or just sitting on say 70ks in 4th or 5th (manual gearbox) It is fine idling or when i get up it but it jumps around if i just sit on one speed or lightly accalerate. Its driving me insane!! please help. thanks
Borrow your mates MAF sensor, IAC valve and TPS sensor. Last two are two sensor on throttle body and only have 2 screws apiece holding them on, and come off without removing anything else. See if that fixes the problem. If it does replace one at a time with your ones until you find the culprit. If it doesn't then replace with your parts and get a error code check done on car. Most auto sparky's I've been too have down it for free.
Ronald Reagan (1986)
ok thanks mate il give it a go. Il let you know how i go..
