hey, for a while now i have noticed this problem, when i start my car from cold it starts perfectly with no trouble. however, when the car has heated up, the car will have like 3 realy slow cranks before it will start, and its slowly getting worse, today it nearly did not start.
i checked the voltage of my battery when car is off, which was around 12 ish, and when running it was at high 13's, but during the period when i crank it over and the car is hot, voltage dropped down to like 7, 8, 9 volts.
just wondering what the normal voltage drop should be, and what i should look at replacing. the battery is only a year old, and i dont want to replace anything that i dont need to.
thanks for your help.
richard
Check the positive wire that goes to the starter motor, make sure it is tight and that the bolt doesn't actually move in the solenoid.
