Results 1 to 4 of 4
Thread: Low level coolant light staying on, even though coolant has been topped up
    VT Calais series 2
    Apr 2010
    Default Low level coolant light staying on, even though coolant has been topped up
    Hello, can anyone help me?
    Im new here and not very mechanically minded. Just today my low level coolant radiator light came on and I went to check and see if the coolant level was low. When I checked, I noticed that there was still a fair bit of coolant, but a little below the line. I topped it up and noticed that the warning light was still on. I took the oil cap off just to make sure there was no water and oil mixture and there wasnt. I also pulled the dip stick out to check the oil and noticed that it looked fine. Can anyone tell me if they have had this problem before and if it was only the low level coolant sensor that needed replacing?
    VT Calais series 2
    Apr 2010
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Have you bled the coolant, could be an air pocket near the sensor.
    Ronald Reagan (1986)
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by acarmody View Post
    Being a Gen 3 it has no bleeding screw because the coolant reservoir is at a higher level than the engine, eliminating the need to bleed it.
    It is most likely that the sensor needs replacing.
    MY RIDE
  1. coolant level in radiator
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-10-2009, 05:48 PM
  2. Coolant Level Sensor/Warning Light
    By mulligan-can in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-06-2008, 12:20 PM
  3. Coolant level
    By WGN Berlina in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-03-2008, 10:23 PM
  4. Coolant Level
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2007, 08:31 PM
  5. Radiator Coolant Level...
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2005, 08:54 PM
