i have a few sounds that bug me and would like them fixed, know why the noises are occurring or least of all are the common
- when i first open my passenger power window it clunks
real heavily, the glass drops onto the window lift.
- whenever i press the accelerator i hear a sucking of air sound around the passenger side dash (mainly hear it at low revs)
- rattle behind the dash
any information would be greatly appreciated
You can also hear the air sucking noise in my VX commodore.. i just assumed it was the air filter.. i know with the K&N and the pod filters they have a fairly loud intake noise..
as for the windows im not to sure...
Ashes to ashes and dust to dust, if it weren't for Fords our tools would rust.
Type in - hissing noise - up the top of this page in the search window and it will tell you all you need to know
Window probably needs the nylon slider pucks replaced, they're on the bottom of the window. They fit in the runner and the scissor arms of the actuators plug into them.
Hissing sound will most likely be the aircon solenoid block or one of its' hoses.
Rattle could be anything from a loose screw to a stray coin... good luck. Might help if you get a mate to drive while you use a short piece of garden hose as a stethoscope. Have fun.
