Results 1 to 3 of 3
Thread: VT Air conditioning problem
    VT Berlina Wagon
    May 2010
    Cairns
    Default VT Air conditioning problem
    Can anyone help me out Plz. I have 99 VT Berlina Wagon. My aircon has climate control . Problem is that will only blow the cold air out of the vents that are for the wind screen. Have tried all settings eg: face,feet and both. No air at all comes out at feet, face and rear air vents. Its a pain when driving in the rain as windscreen fogs up. Live in Far Nth QLD so need the aircon. Cheers Deb
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    check your vaccum hose, which is located at the back of the intake manifold and see if that has pop off..
    NEVER LATE IN A 355ci
    '98 vt berlina
    Feb 2010
    to be sure, replace that short hose between the intake manifold and the one-way vacuum valve anyway. when my did it, the hose was still intact except the end bit has expanded and loose, causing vacuum leak. my mechanic even went to the extend of putting some glue to make sure it's properly sealed
  1. VT Air Conditioning Problem
    By agault in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-06-2011, 03:34 AM
  2. VX air conditioning switch problem
    By surfer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2010, 08:14 PM
  3. Air Conditioning Problem VZ
    By Anfernee0525 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-11-2009, 10:04 PM
  4. Standard air conditioning control: illumination problem
    By jazza15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-07-2008, 11:39 PM
  5. VX Air Conditioning Problem
    By tdog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2007, 09:04 PM
