Could someone please post a pic of the rear sway bar in a 1999 vt commodore please as iam having a hard time locating it on my vt...unless the pre owner didnt install it
Real cars don't power the front wheels, they lift them
The stabiliser/sway bar is a bit hard to get a pic of as it is held in rubber or neoprene and steel mounts on top of the frame supporting the diff. It has two pins/links similar to the front sway bar links apparently attached to the lower control arms
yep found it! thanks heaps mate
thinking of swaying my stock 1 out for a 18mm heavy duty one from ebay
Be very careful removing it as the GMH service manual says you need a special tool to realign the frame or you will be chewing tyres worse than usual
