Hi all, i just replaced the headlights on on my wh statesman with new ones i bought off ebay, all is well except for one little nagging issue, parkers and low / high beams work but when i have low beams on and switch to high beam, the high beams come on on both lights but the right hand low beam dims dramatically! Anyone had this happen before? Any help appreciated thanks.
anyone? ...................
I'l give it a go, have you checked all the connection? sounds like an earth issue to me, double check all your globes are in properly
well the only thing i can think of is one of the globes arent in properly........
well i dont know what happened, but i managed to get the main r/h globe to work properly on both low/high beams, but in the process i have managed to blow the little high beam globe, so ill get one tomorrow on my way home from work and hopefully that will be the end of it......
