Results 1 to 4 of 4
Thread: New/replacement remote key heads
    VX Commodores S
    May 2010
    Question New/replacement remote key heads
    I have purchased new key heads (over a year ago) from a locksmith, they have been coded and are ready to be swapped over. I have 2 keys, I swapped one over but have never swapped my spare key over. Originally when i swapped the first key over i got a piece of paper that had some sequence like unock car swap key head start car lock car or something like that. I have lost the piece of paper and was wondering if anyone knows what that sequence is and/or if it neccessary? Can I just swap the key head over and it work?
    Thanks.
    Vt Clubsport
    May 2009
    have you had the actual remotes programmed to the car? if so, i think it should be fine... but better wait and see if anyone with abit more knowledge can help you.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    i'm pretty sure its,
    unlock the car with the current key
    start the car with the new key
    switch off and lock with the new key
    Chev badges are an instant fail
    87LAG's Avatar
    87LAG is offline BOOSTED 6 FTW
    VX S S2 AUTO RAPTORCHARGED
    Apr 2010
    THE SWITCH
    Got mine a few weeks back
    1. Open/unlock with old key
    2.get in and manually push down locks
    3.start car with new key and run for 60 seconds
    4.turn off and it should unlock with new key
    gl
  1. Remote engine start on VXII berlina with factory key remote
    By cougar1985 in forum Electrical Wiring / Questions
    Last Post: 02-11-2010, 01:32 PM
  2. ECU/BCM replacement, and remote key replacement/ignition replacement
    By skunks.monks in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:08 PM
  3. VT2 Remote
    By AdamAnt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-04-2007, 04:18 PM
  4. remote replacement...
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2005, 10:32 PM
  5. Replacement Keys / Remote
    By Lint in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2004, 04:58 PM
