Results 1 to 2 of 2
Thread: VT Strut Problems, Help!
    VT S Pack
    Apr 2010
    Default VT Strut Problems, Help!
    the rod in my strut brace has popped out of it's top location, i've taken it out, but now i need to know how to get the bar low enough so i can put it back in.. does this make sense to anyone? sorry i'm kind of car illiterate
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    I think it is the sway bar link that you are referring to. If it has popped out as you say then there is a problem with it because they should not be able to just pop out. Have a look at the other side and measure the length of both of them because it could have broken a bit off the end so it popped out or the washer could have the centre torn out of it. You will need to undo the other side to lower the bar.
  1. vs/vl strut
    By BIG DYL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-04-2010, 12:00 PM
  2. strut balljoint
    By skyper in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2008, 09:49 PM
  3. strut?
    By harro_VR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2007, 04:48 PM
  4. HDT Strut brace
    By jasonhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2006, 05:20 PM
  5. VS strut into VN SS
    By Bruce Davidson in forum Projects
    Last Post: 05-04-2005, 01:42 PM
Tags for this Thread
