Results 1 to 11 of 11
Thread: CV6 Monaro taking off supercharger
    2005 VZ SV6
    Aug 2009
    Default CV6 Monaro taking off supercharger
    Hey guys, i know i probably shouldnt post this here, but you're all a wealth of knowledge, im sure that you'd be able to tell me how plausible it is to simply 'take off' the supercharger from a CV6 ? If so, what else would need to happen, or if not, why is it not possible?
    any help greatly appreciated, thanks guys !
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Stop bagging him, he needs all those speakers to drown out the bullshit he dribbles.....
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Would need, different manifold and plenum chamber, different injectors, L36 ECU and loom, ECU matched to BCM. I'm sure I've forgotten stuff, but not worth it. Are you on L's or P's?
    Ronald Reagan (1986)
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    It wouldn't run the best as the L67 had a lower compressor ratio compare to the normal ecotech engine
    NEVER LATE IN A 355ci
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    the question remains... why would you do this?
    I haven't lost my mind, it's backed up on tape somewhere
    VX Berlina
    Apr 2007
    Usually for someone on P's or L's. They ope to replace it later when they have their opens.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    would prob be cheaper to just go buy an ecotec with the ecu
    Chev badges are an instant fail
    VX Berlina
    Apr 2007
    Yeah I agree. Slot L36 in, wire up, and when you get opens, rip out, slot L67 in and sell L36 for some money back.
    VS L67
    Sep 2007
    BrisVagus
    Remove the rotor pack from the blower case and use a blanking plate to cover the hole (you can get these from ZZP Performance in the USA) then have your ECU re-flashed with an standard ECOTEC tune.
    You will find that the engine will be down a little on power compared to a normal ECOTEC as your compression ratio is a little lower.
    If you are serious about doing it, contact someone like Greenfoam when you want the chip done and get him to add a little more timing to it, so you get a bit more go from it.
    Depending on the tune that is used you may have to change the injectors back to stock L36 ones. You can get these for next to nothing.
    The blower plate is $49.00 USD, I am not sure what Greenfoam would charge for a chip. The whole process would take less than an hour to do.
    When you are ready to go back to boosted goodness, just reverse the process and away you go.
    VX Berlina
    Apr 2007
    If the OP really is doing this for L or P plates then a blocking plate won't work. Cop will see supercharger and then issue fine/tow car.
    VS L67
    Sep 2007
    BrisVagus
    I can kind of see where you are going but it is not like disconnecting the belt. The whole internals are gone which means that it is not supercharged.
    With the blank off plate in place and the standard engine cover on, you would be hard pressed to know that it was a L67, unless you are up on that kind of thing.
    If you did get caught you would just have to present the car and there should be no problems, but each to their own.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    VX Berlina
    Apr 2007
    Traffic Police up here with us are very good with cars. No reason other states wouldn't be.
    I still reckon slot an Ecotec in.
  1. taking out old cd player
    By Ryaz11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2009, 07:20 PM
  2. Taking out the plastics in the car...
    By cds in forum Electrical Wiring / Questions
    Last Post: 23-11-2009, 07:11 AM
  3. Taking things off
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2008, 06:14 AM
  4. When taking out my engine
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2008, 09:30 AM
