Results 1 to 9 of 9
Thread: Tow hook on a VX
    VX Executive
    Feb 2008
    Default Tow hook on a VX
    I know there's a hatch in the rear bumper that supposedly should have access to a rear tow hook or a latch. But where do you secure a towing line if you have to tow the VX from the rear? I dont want to secure the tow cable to trailing arms or chassis parts incase it'l tweak the car. similarly, i cant find a tow hook in the front of the VX either.
    Just to let everyone know, I dont have to tow the car but just in case. Can i install a tow hook?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I thought you weren't supposed to tow a car behind another, at least not without disconnecting the tailshaft and stuff.
    Ronald Reagan (1986)
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Quote Originally Posted by acarmody View Post
    that only applys in victoria doesnt it?
    VT Acclaim Wagon
    Oct 2008
    cars are not legaly able to tow other cars in NSW except with a specially designed tow bar. The towbar is 3 metres long with a normal tow hitch on 1 end and a pair of locking chains on the other end. There is another which is shaped like a triangle. both require a driver in the towed vehicle and knowing the beureaucrats in public service, the rules for them have probably changed since I last used these things. Just 1 other thing, on a lot of cars, the so-called "tow rings" are in fact shipping tie down points and not designed for towing at all. The Toyota manual I have explicitly mentions this.
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    Graham is correct. In most cases, the 'tow hooks' are merely where the car is secured to the boat/truck on delivery to the dealer. After that they are meant to serve no purpose.
    VT Acclaim Wagon
    Oct 2008
    And I learned that the hard way, I nearly ripped the so-called "tow hook/ring" completely off an EF Falcon I had to move.
    VX Berlina
    Apr 2007
    I would never tow a car with another car except for in the most extreme cases, like out bush with no other option. Reason being that you are relying too heavily on the driver of the other car. The other driver has to know exactly when you are braking, turning or anything else, because they are so close there is no time to think.
    VX SS
    Jul 2005
    East of Melbourne
    If it is an auto you need to remove the tailshaft if flat towing for any distance or you risk damaging the auto trans.
    VX Executive
    Feb 2008
    Thats the thing i completely forgot. I think i'l leave the towing to the range rover instead. Now thats a beast!!
  1. VE SV6 rear tow hook?
    By Shamous69 in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-03-2010, 10:01 AM
  2. No Front Tow Hook
    By Adventra LX6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-06-2006, 08:49 PM
  3. How do you hook up the horn in a VN/VP/Vr/VS??
    By ssn8r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-02-2006, 09:47 PM
  4. Where to hook it up?
    By Liem in forum Electrical Wiring / Questions
    Last Post: 04-09-2005, 07:56 PM
